Show Pics of how to hook up MBC to a Tial Wastegate
I've done a search-- but i still can't find what i'm looking for. I want to see on my tial where the fitting connect-- and where the mbc connects to. Does the bottom of the wastegate still go to a pressure source, and the top goes to the MBC. and the other line of the MBC goes to a pressure source as well??
Re: Show Pics of how to hook up MBC to a Tial Wastegate (integranator)
alright dude ill help you out. the side port goes to a vacuum source, the top port goes to your mbc. if you cant figure it out after that give me your MBC good luck
Re: Show Pics of how to hook up MBC to a Tial Wastegate (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">alright dude ill help you out. the side port goes to a vacuum source, the top port goes to your mbc. if you cant figure it out after that give me your MBC good luck </TD></TR></TABLE>
I thought the top fo the wastegate was for EBC?
Re: Show Pics of how to hook up MBC to a Tial Wastegate (Civicman86)
the side port of the tial wastegate is for a dedicated vacuum/pressure source.
the top port is to be used as a regulated pressure source in conjunction with the side port.
the simplist/cleanest way ive found to run these hoses is:
1.plug compressor housing port with 1/8" npt plug if necessary.
2. route hose from the intake manifold plenum to the side port of the wastegate. this supplies an unregulated vacuum/pressure source to the bottom of the diapraghm.
3. locate mounting position for regulator/boost controller.
4. in the vacinity of the regulator mounted position, cut the hose running to the side port of the gate and T it.
5. route a hose from the end of the T to the inlet of the regulator.
6. route a hose from the outlet of the regulator to the top of the gate.
hth
edit: sorry i didnt provide pictures at this time...
hth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 »</TD></TR><TR><TD CLASS="quote">I thought the top fo the wastegate was for EBC?</TD></TR></TABLE>
Correct, the top port is for an Electronic Boost controller and the Side port of the wategate is for a Manual boost controller. and then the other port on the MBC you need to run to a vacuum source like the side of the turbo or to the intake manifold. My turbo XS MBC is hooked up this way (side port of wastegate-MBC-Intake Man. vacuum).
MBC goes inline on the pressure line from intake manifold to the side port of the wastegage.
With an MBC leave the top port open.
Re: Show Pics of how to hook up MBC to a Tial Wastegate (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">MBC goes inline on the pressure line from intake manifold to the side port of the wastegage.
With an MBC leave the top port open.</TD></TR></TABLE>
Re: Show Pics of how to hook up MBC to a Tial Wastegate (PrettyLude)
http://www.tialsport.com/tech.html
There ya go. Click on Wastegate Install Diagram. One should have been included in your Wg unless bought used.
Re: Show Pics of how to hook up MBC to a Tial Wastegate (Laserjock)
i ran mine : turbo compressor->mbc->side port of wastegate
top port is left open.. it works perfectly
Thats exactly what I thought. Other dude said hook it up to the top. Just wanted to make sure I had it clarified.
Thanks guys!
Thanks guys!
GeorgeJetson
06-12-2003 12:58 PM
