3rd or 4th gear dyno runs much difference???
Old Apr 29, 2003 | 12:57 AM
Drew Peacock's Avatar
Default 3rd or 4th gear dyno runs much difference???
Hello I have been told a few times by various people that a dyno run in 3rd gear will give a higher reading then a run in 4th gear ... I have seen people post up graphs where both gears looked much the same.
The shop I go to usually do's 3rd gear runs for some reason can someone shed any light here.??
Old Apr 29, 2003 | 10:56 AM
Default Re: 3rd or 4th gear dyno runs much difference??? (turbozxi)
Someone must know?
Old Apr 29, 2003 | 02:02 PM
Foozball26's Avatar
a gear is a torque multiplier so when you have it in 3rd gear you are going to have a higher number than 4th b/c of the steeper gear ratio.
4th gear on almost all cars are 1:1 or very close to it so thats why you want to dyno in 4th
Old Apr 29, 2003 | 02:07 PM
boosted hybrid's Avatar
Gear ratios trade rpm for torque. The higher the gear ratio, the higher the torque reading. The higher numerical value, the faster you'll travel through the rpm band. The lower the numerical valve, the slower you'll travel through the rpm band but the more torque you'll transfer out. The power doesnt change, its essentially power in=power out. The transmissions have 15% drivetrain loss, so that has to be factor in.
Old Apr 29, 2003 | 07:34 PM
Default Re: 3rd or 4th gear dyno runs much difference??? (boosted hybrid)
Thanks for the reply's so its the torque reading that would be higher not the horsepower?? Is that correct
Old Apr 29, 2003 | 07:42 PM
DIRep972's Avatar
Smarter than you
Yeh the torque @ the wheels is higher in 3rd gear then in 4th. But the dyno doesn't know what kinda gears ur car has. The dyno only knows rpm and mph. it uses those to figure out what gear u have then divides it out as if u didn't have a transmission and gives u the #'s you see on a print out. 3rd/4th gear dyno #'s should be the same, or very close. I have actually heard of 4th dyno'ing higher then 3rd because of the added load on the motor.
If u were to calculate actual torque at the wheels through the tranny, 1st gear would be about 4 times as high as what u read on a dyno print out, 2nd is around 3 times as high, 3rd would be around twice as high and 4th would be about the same. thats why they say 4th is almost a 1:1 ratio.
Old Apr 29, 2003 | 07:58 PM
raene's Avatar
Default Re: 3rd or 4th gear dyno runs much difference??? (IRepD)
Good topic!
So I should be dynoing in 4th with my JDM S1 transmission?
Reason I ask is I'm going this Saturday morning...
Old Apr 29, 2003 | 07:59 PM
Power in=Power out
Gear Ratio=Number of teeth of gear 1/Number of teeth of gear 2
Gear Ratio=Tin/Tout
Gear Ratio=Rpm out/RPM in
For example the LS transmission:
3rd gear: Gear Ratio=Gear 1 (counter)/Gear 2 (main)=33/26=1.26:1
4th gear: Gear Ratio=Gear 1 (counter)/Gear 2 (main)=30/29=1.03:1
Now apply Gear Ratio=RPM out/RPM in at 4,000 rpm for example.
3rd Gear: 1.26=RPM out/4,000 RPM out=5040
4th Gear: 1.03=RPM out/4,000 RPM out=4120
Now apply Gear Ratio=Torque in/Torque out at 122 ft lb (engine torque going into transmission)
3rd Gear: 1.26=122/Torque out Torque out=96.8 ft-lb
4th Gear: 1.03=122/Torque out Torque out=118.44
This is all hypotetical, but it shows you that 3rd gear gains more rpm but less torque, where 4th gains more torque less rpm.
Old Apr 29, 2003 | 08:15 PM
I just phoned the tuner, yes IRepD thats correct third actually gives a slightly lower HP reading tuner said 4th gear is more efficient by about 1-2% so you will get a slightly higher reading in 4th he said the lack of gearing has something to do with it. Yeah the torque certainly does multiply in the lower gears.
Cheers all, Boosted Hybrid I almost understand what your trying say
Old Apr 29, 2003 | 10:08 PM
FredoSP's Avatar
good info guys
Old Apr 29, 2003 | 10:56 PM
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: 3rd or 4th gear dyno runs much difference??? (FredoSP)
so 4th gear would yield better hp...someone explain the tq please i cant think right ...jsut plain and simple please
Old Apr 29, 2003 | 11:45 PM
pissedoffsol's Avatar
25 Year Member
Default Re: 3rd or 4th gear dyno runs much difference??? (CiRcUiTsi)
**** numbers--- whats better for TUNING?
Old Apr 30, 2003 | 12:23 AM
Just to keep it simple, the gear ratios ratios multiply the torque so the lower gears having higher ratios give much higher readings for torque. Yeah 4th gear is best for an accurate torque and hp reading.
Old Apr 30, 2003 | 12:50 AM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote"> Yeah 4th gear is best for an accurate torque and hp reading. </TD></TR></TABLE>
like i said, who cares about numbers... PC racers??
what is better for spitting out a more reliable a/f to the wideband sniffer?
Old Apr 30, 2003 | 01:14 AM
TEAMGENDAI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Power in=Power out
Gear Ratio=Tin/Tout
</TD></TR></TABLE> all this sounds pretty good. but i would not dyno a low hp car in 4th gear. i would dyno a high hp car in 4th gear, other wise a high hp car will spin tires in a lower gear and will not get an accurate reading. also in a high hp car it will a sample more af points. thats about it . anyway good post boost hybrid
Old Apr 30, 2003 | 11:22 AM
Default Re: 3rd or 4th gear dyno runs much difference??? (delvtecsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delvtecsol &raquo;</TD></TR><TR><TD CLASS="quote">
what is better for spitting out a more reliable a/f to the wideband sniffer?</TD></TR></TABLE>
Well numbers do reflect on how well you have done the job would you prefer a dyno readout without them? To answer your question there would be no difference after all its an A/F ratio thats all.
Old Apr 30, 2003 | 11:30 AM
DIRep972's Avatar
Smarter than you
When I dyno'd my car we were doing all the pulls in 3rd gear. I wanted to try a 4th gear pull to see if the added load changed anything. Everything stayed the same and I made withen .2hp of the pull before. Dont remember if it was higher or lower, wasn't much difference.
Old Apr 30, 2003 | 05:29 PM
93LSivic's Avatar
Default Re: 3rd or 4th gear dyno runs much difference??? (Mr. Belding)
You will want to dyno in whatever gear is closest to 1:1. It'll give the most accurate readout of engine power without gearing swaying the results. Usually for our cars 4th is the best gear.
Old May 15, 2003 | 04:35 PM
Quick 200k Mile Motor's Avatar
Default Re: 3rd or 4th gear dyno runs much difference??? (93LSivic)
I know from experience dyno in 4th gear is best in these transmission G3-GSR, 90-91' LS, and JDM S1. (I don't really know about the others)
Old May 15, 2003 | 04:53 PM
95c1v1cs1's Avatar
Default Re: 3rd or 4th gear dyno runs much difference??? (Quick 200k Mile Motor)
when i got my car dynoed they asked me for my final drive ratio and the 3rd gear ratio. Do all dyno places do that??
Old May 18, 2003 | 08:01 AM
25 Year Member
Default Re: 3rd or 4th gear dyno runs much difference??? (95c1v1cs1)
i've been to 3 places, and not one has asked.
maybe they knew what is was (doubtful), or just don't care (most likely)
VTIargentina
Oct 23, 2009 10:43 AM
daluv
Engine Management and Tuning
Aug 27, 2008 05:16 PM
cruzersi99
18
Aug 24, 2005 09:08 AM
Maxime
Jul 25, 2002 10:50 AM
TypeR0149
Mar 19, 2002 02:59 PM
