DIY turbo SOHC guys.. how'd you do you oil feed/return
I wanna know where you guys tapped for your feed lines and where on the oil pan for the return on your sohc's with pictures if you got em and what all fittings/lines you used. thanks
Re: DIY turbo SOHC guys.. how'd you do you oil feed/return (BottleFedBigBodyLX)
oil pressure sensor for feed
upper part of pan for return..weld on a 10an fittin and drill the hole
on a sidenot i didnt tee off myblock i used aL and didnt pout back in the sensor..and havent even got a oil light yet after a fewweeks
New User
Re: DIY turbo SOHC guys.. how'd you do you oil feed/return (IDriveAHonda)
See the site in my sig.
Return is drilled hole and welded pipe on pan. As low as I could get it.
Secret: Pipe I used is 1/2" conduit, super cheap and easy to weld.
Randy
Randy
