where to tap for egt
Old Apr 26, 2003 | 10:33 PM
joeski's Avatar
Default where to tap for egt
ok i got a greddy egt and have been hearing lots of diff ideas but was jus wondering where the best place to tap for the probe would be
Old Apr 26, 2003 | 11:00 PM
Trial User's Avatar
Default Re: where to tap for egt (joeski)
I have heard everybody having there's in the number 3 cylinder exhaust port. I have mine about 3 inches from the exhaust exit from the turbo. Your readings will be higher on the number 3 cylinder since it is closer to the cylinders and also becasue usually the number 3 is the one that goes first. For whatever reason it seems to have more heat and more chances of detonation.
Old Apr 26, 2003 | 11:50 PM
ash.zero's Avatar
Default Re: where to tap for egt (RACECAR)
i tapped mine on runner 4 for space reasons. how much of a difference will there be compared to runner 3?
Old Apr 27, 2003 | 12:40 AM
Trial User's Avatar
Default Re: where to tap for egt (ash.zero)
Runner 3 is the cylinder most likely to fail and it tends to run a higher temperature. This way you will know the highest temperature in the spot that is most likely to malfunction first.
Old Apr 27, 2003 | 12:58 AM
DSC's Avatar
DSC
I did a search on this last night.
https://honda-tech.com/zerothread?id=221258
Old Apr 27, 2003 | 01:37 AM
TurboDANDEE's Avatar
Default Re: where to tap for egt (DSC)
mine is on #3, about 3in. away from the head.
If i could do it again, i think i would put it on #4 because i blew that cylinder before and i've seen a couple of motors done the same. plus i think #4 gets the last of the coolant flow, the coolant flows from #1 to #4.
Old Apr 27, 2003 | 08:57 AM
Quick 200k Mile Motor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I did a search on this last night.
https://honda-tech.com/zerothread?id=221258</TD></TR></TABLE>
that post said 2" away from head, on the #3 runner
NAH2B
Mar 2, 2009 05:09 AM
vtecdamian
13
Feb 9, 2006 10:04 AM
hate me.
Aug 11, 2004 07:17 PM
SupraDai
May 14, 2004 07:56 PM
Ochux
Sep 16, 2001 10:12 PM
