TPS Hack, what is it????????
Old Apr 27, 2003 | 11:43 PM
hybridb18's Avatar
Default TPS Hack, what is it????????
i understand that the ecu will go into open loop at a certain tps voltage. my question is, with this tps hack, is all you have to do is adjust the tps sensor so the voltage is greater at lower throttle? At what voltage does the ecu throw it in open loop? i know it is supposed to be .5v at closed throttle, and 4.5V at wot. what should i adjust the tps to at closed throttle? Are there any disadvantages other than a bad idle? what else does the ecu use the tps sensor for?
Sorry about all the questions, just trying to understand this a little better, thanks
Old Apr 28, 2003 | 12:21 AM
hybridb18's Avatar
Default Re: TPS Hack, what is it???????? (hybridb18)
ttt
Old Apr 28, 2003 | 12:25 AM
Sonny's Avatar
The TPS hack is mainly for JRSC people. You basically force the TPS voltage to 4.5 volts whenever boost is present. This is done by using the pressure switch that comes with the JRSC kit.
Sonny
Old Apr 28, 2003 | 04:57 PM
hybridb18's Avatar
Default Re: TPS Hack, what is it???????? (Sonny)
well couldnt i just adjust the tps sensor so that it would read 4.5 volts before full throttle? thus putting it in open loop sooner?
Old Apr 28, 2003 | 05:32 PM
Sonny's Avatar
If you do that, it will not read .5 volts at idle (what it needs to read).
Sonny
Old Apr 28, 2003 | 09:04 PM
hybridb18's Avatar
why does it need to read .5 volts at idle? Will it throw a CEL if it isnt .5 volts? what else does the ecu use the TPS sensor for?
Old Apr 29, 2003 | 07:21 AM
JT's Avatar
JT
Some info on tps...
http://www.hondata.com/techidle.html
nutball72
Nov 11, 2006 07:14 PM
TheSav
Apr 10, 2006 11:23 PM
evo
Apr 9, 2002 09:39 PM
boosted hybrid
Apr 1, 2002 06:20 AM
soHybridized
Mar 13, 2002 10:22 AM
