Bolts !!!
Old Apr 29, 2003 | 12:03 AM
swlabhot's Avatar
Default Bolts !!!
Is anyone having trouble with bolts on the turbo flange and downpipe rattling loose? Mine rattles loose everytime after some hard driving. To my horror my downpipe nearly fell out with just 2 hanging bolts out of four holding it (2 had fllen off) on when I heard a gas leak and checked it. The bolts on the turbo flange also work themselves loose even after tightening them. I get so paranoid now that after everytime I drive it, I gotta pop the hood to check every bolt to make sure !
What can I use to make sure these ***** stay in place and never ever come loose?!?!
Old Apr 29, 2003 | 04:30 AM
BROOD's Avatar
Default Re: Bolts !!! (swlabhot)
replace the bolts with studs/nuts
Old Apr 29, 2003 | 05:04 AM
bottlefedb18c1's Avatar
studs work but they will work loose over time they did for me then i put a bit of high temp silicon on the treads and duble nutted them and never had a problem
Old Apr 29, 2003 | 05:07 AM
01ITR#700's Avatar
Default Re: Bolts !!! (boostfedb18)
I have the same exact problems. MY WG bolts, and WG dumptube bolts like to come loose as well.
M
Old Apr 29, 2003 | 05:21 AM
Default Re: Bolts !!! (01ITR#700)
i never really has a problem with the WG i always use alen bolds with lock walshers
Old Apr 29, 2003 | 08:06 AM
TheShocker's Avatar
I put red loctite (high temp) on my bolts...they stay!
Old Apr 29, 2003 | 08:19 AM
LSiTurbo's Avatar
Default Re: Bolts !!! (TheShocker)
i had this problem also, i fixed it by tighting the bolts really tight! seriously... it works...
mrrugsr
Mar 1, 2006 07:55 PM
TRE_
Sep 26, 2003 10:32 AM
hybrid901
Jun 7, 2002 03:09 PM
austrian type-R
Apr 19, 2002 07:56 AM
