Cheap Oil Feed / Distribution Block Fitting!
Old Sep 1, 2003 | 02:15 PM
RenoRacing's Avatar
Default Cheap Oil Feed / Distribution Block Fitting!
Hey guys, just showing you what i picked up for 16$ for all the parts(not including lines). It's all metric NPT's but easy to adapt to anything. The bottom is a 3/8"NPT and then it splits to three 1/4" NPT. I have it set up for Vtec oil feed and turbo oil feed and then you have a port to run your stock oil pressure sensor or an aftermarket gauge sender. I have it mounted to the firewall now w/ a 16" feed line to it. Let me know if you have any questions.
(the line is just for demonstration purposes)
Old Sep 1, 2003 | 02:51 PM
mos's Avatar
mos
Default Re: Cheap Oil Feed / Distribution Block Fitting! (HavokRacing)
Nice. Looks like that'd work well. Now lemme be the first to ask, where did you get that thing?
Old Sep 1, 2003 | 03:04 PM
RenoRacing's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (mos)
let me surprise you and tell you home depot! in the compressor parts section. $5.95 for the block and then just a bunch of adapters.
Old Sep 1, 2003 | 03:38 PM
paulzy's Avatar
Nice....might have to pick that up for my kits...
Old Sep 1, 2003 | 03:43 PM
The Brown Kid's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (Paul_Vang)
thats pretty cool ill have to go and pic one up
Old Sep 1, 2003 | 04:23 PM
Hayasa15's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (The Brown Kid)
did you get the fitting that goes into the block from home depot as well?
Old Sep 1, 2003 | 05:09 PM
RenoRacing's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (Hayasa15)
No, i have several rubber hydraulic lines that are 1/8NPT swivel fittings, they are like 16-18" long. I just got an adapter that goes 1/8"npt to 1/8"bpst or whatever it is.!, i just mounted it underneath my intake manifold to one of the manifold support bracket holes that noone uses.
Old Sep 1, 2003 | 05:52 PM
Hayasa15's Avatar
did you get the 1/8"npt to 1/8"bpst off of h-t or where?
Old Sep 1, 2003 | 06:01 PM
RenoRacing's Avatar
there is a place about 3 miles from my house called "the hose and fittings store" they got everything, like $7 each but they are better than crossthreading.
Old Sep 1, 2003 | 07:19 PM
PHiZ's Avatar
Great find man!!
Anyone know what BPST, AN stands for?
Also I found a place that has the fittings, it's called http://www.aircraftspruce.com/index.php
They will send you out a catlog if you request.
Havokracing, post the address/phone number of that store, maybe ppl local to you can get hooked up.
-PHiZ
Old Sep 1, 2003 | 07:58 PM
Hayasa15's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (PHiZ)
i searched the site and could not find the BPST fittings
Old Sep 1, 2003 | 08:16 PM
senpai's Avatar
summitracing.com has it
Old Sep 1, 2003 | 08:17 PM
94TurboGSR's Avatar
Isn't it BSPT?
British Standard Pipe Tapered...
AN has something to do with being anodized, I would think. Anyone know for sure?
Old Sep 1, 2003 | 09:00 PM
twkdCD595's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (94TurboGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94TurboGSR &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it BSPT?
AN has something to do with being anodized, I would think. Anyone know for sure?</TD></TR></TABLE>
british standard pipe thread
Old Sep 1, 2003 | 09:31 PM
RenoRacing's Avatar
Default Re: Cheap Oil Feed / Distribution Block Fitting! (twkdCD595)
Yeah it's bspt. i got the s and p backwards the first time. I could buy some and sell them if you guys are interested. I could probably get them for like $10 shipped. it's just the little one at the end of the black line, you'd only need one of them to do the same setup as i did. I could probably do the whole setup for $50 shipped for all the fittings w/o any lines and your choice of -3AN,-4an or -6an straight or 90° fittings. Let me know if anyone is interested in all 10 or so fittings for that price.
they will all be brand new and all you'll need is a line w/ 1/8" npt male ends.
Modified by HavokRacing at 11:10 PM 9/1/2003
Old Sep 1, 2003 | 10:21 PM
RenoRacing's Avatar
I'll get one together tomorrow and get some pics and see if anyone's interested.
Old Sep 1, 2003 | 11:03 PM
paulzy's Avatar
not to hijack this thread, but if you need some 1/8 NPT to BSPT fittings, I have like 30 of them
Old Sep 1, 2003 | 11:15 PM
lazerus's Avatar
Default Re: (Paul_Vang)
National Pipe Tapered.
British Standard Pipe.
Army-Navy
Old Sep 2, 2003 | 05:36 AM
Flamenco-T's Avatar
Default Re: (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">National Pipe Tapered.
Army-Navy
NPT = National Pipe Thread
stealthmode62
Oct 3, 2011 06:14 AM
Hondasi88
Apr 2, 2005 06:41 AM
Black R
Jan 24, 2005 10:41 AM
zbower7
May 14, 2004 01:42 PM
HX_Guy
Dec 26, 2001 06:30 AM
