Nitrous Question.
Old Sep 2, 2003 | 01:53 PM
drvfast's Avatar
Default Nitrous Question.
sorry for the newbie question but i heard when you are spraying you shouldn't full throttle shift is this ture? the reson im asking this because i full throttle shift all the time and if i get the bottle i wont be able to do this anymore if the question is a true statement. thanks
Old Sep 2, 2003 | 02:22 PM
drvfast's Avatar
Default Re: Nitrous Question. (drvfast)
anyone
Old Sep 2, 2003 | 02:27 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
if your using a zex kit. It's going to hit the fuel-cutoff and you don't want that.
Old Sep 2, 2003 | 03:24 PM
drvfast's Avatar
Default Re: Nitrous Question. (HybridcivicLS-T)
ok thanks for your help
Old Sep 2, 2003 | 04:30 PM
RyanEJ8's Avatar
The only time I recommend it is if you have a Hondata with the full throttle shift option.
Old Sep 2, 2003 | 04:39 PM
boosted92's Avatar
Default Re: Nitrous Question. (RyanCivic2000)
Spend a few bucks, get an MSD window switch, set the on pill for NO lower than 3000 RPM's (you should be more worried about this than not being able to shift @ wot) and set the off point a wee bit above your shift point but before redline. Combine that with your wot switch and shazam.
Old Sep 2, 2003 | 08:31 PM
99blusi's Avatar
Default Re: Nitrous Question. (boosted92)
Pretty much what has been said, you don't want to be spraying nitrous and hitting fuel cut at the same time...not good.
95accordh22a
Feb 26, 2005 08:35 AM
JSpin
Aug 18, 2004 06:50 PM
Si Erik
12
Oct 4, 2003 07:53 PM
cr-x si
Oct 2, 2002 08:33 AM
hondanacura4life
May 15, 2002 04:03 PM
