4 and 5 bolt discharge & their necessity to hack at the block
Old Sep 3, 2003 | 01:11 PM
tegasaurus's Avatar
Default 4 and 5 bolt discharge & their necessity to hack at the block
I remember a thread from a long time ago, about this time last year. Showing the comparisson of a t3/to4e 4 bolt and t3/to4e 5 bolt turbos on an inlinepro manifold. One required more block shaving than the other. I plan on using an inlinepro manifold and my new setup vs my old shitty maxrev, however i will still be utilizing my 4 bolt t3/to4e - will this setup work with very minimal shaving, or will i have to mount the compressor on the driver side?
Old Sep 3, 2003 | 01:52 PM
b18b98's Avatar
Default Re: 4 and 5 bolt discharge & their necessity to hack at the block (tegasaurus)
this was a few up
https://honda-tech.com/zerothread?id=609148
Old Sep 3, 2003 | 01:58 PM
TeStUdO's Avatar
here is the thread if you are lazy - https://honda-tech.com/zerothread?id=402894
Old Sep 3, 2003 | 08:54 PM
tegasaurus's Avatar
Default Re: (TeStUdO)
What is needed to perform the 4bolt to 5 bolt conversion? will i need just the housing or the wheel etc. My buddy works at honeywell and can get any garret product for cost so just let me know what i need.
-Ryan
Old Sep 4, 2003 | 12:17 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (tegasaurus)
Its a direct swap if your turbine housing is made to fit a T31 turbine wheel, which I assume thats what you have.
art
neoc03
Oct 20, 2008 07:36 PM
CoreyR
Mar 24, 2007 11:20 AM
D-Man
Sep 12, 2004 06:49 PM
austrian type-R
Sep 19, 2003 08:58 AM
