e manage question.
Old Sep 3, 2003 | 06:29 PM
My95SlvrBlt's Avatar
Default e manage question.
Ive got the greddy emanage to run when i finish my turbo project. And ive got the emanage, ignition harness(using for injectors too), and the profec e01(not necessary to get pressure sensor/harness correct?) Ive got a missing link, but will that be necessary with the emanage, or can i just resell it?
Thanks
Old Sep 3, 2003 | 06:38 PM
REDLNR's Avatar
Default Re: e manage question. (My95SlvrBlt)
You can use the eManage's Boost Limiter Cut (BC) to clamp the MAP sensor voltage going to the ECU. So, no, you do not "need" the missing link any more. If you want the e-01 and the eManage to both use the Greddy Pressure Sensor's boost reading you will need to purchase the $20 cable that shares the boost reading between the two devices. I got mine from MohdParts.com.
Old Sep 3, 2003 | 06:55 PM
Default Re: e manage question. (REDLNR)
What im saying is, will i even need the pressure sensor, and harness since i have the profec e01? And instead of the boost limiter cut, czn i just use the missing link?
Old Sep 3, 2003 | 07:57 PM
REDLNR's Avatar
The e-01 comes with it's own Pressure Sensor, are you saying that you already have one...and then will have two? Your tune would be nicer if you tuned with the eManage's Boost Limiter Cut instead of the Missing Link. Both will accomplish a similar result, but the Boost Limiter Cut will simply clamp the voltage at X voltage at Y RPM while the Missing Link will be altering the reading throughout the range. I'm running the eManage with the Missing Link just because we haven't gotten around to setting up the Boost Limiter Cut, both will work fairly well.
Old Sep 3, 2003 | 08:37 PM
Is the boost limiter cut an option with the emanage, or will i need something extra?
Old Sep 3, 2003 | 08:43 PM
REDLNR's Avatar
No, you do not need anything extra.
EF_kid
May 14, 2006 09:47 AM
civel
Jan 22, 2006 12:00 PM
CarpAngler
Feb 4, 2005 05:30 AM
94greddycivic
Jun 29, 2004 10:51 AM
Whooopasss
May 17, 2003 12:55 PM
