How often should oil be changed in turbo engines??
I was just wanting opinions on how often because I mainly will be on the highway and at the strip once a month. I will be using Royal Purple 10-40 and changing the filter every 3000 and the oil every 6000.
Re: How often should oil be changed in turbo engines?? (TURSpoonEK)
What kind of driving do you do. city driving is worse than highway thats why I thought it would be ok
Re: How often should oil be changed in turbo engines?? (SIXTYdashONE)
I shitcan full synthetic every 1500 miles. If I had a water cooled turbo I suspect it would last until 2000. Feel the oil when it's clean, and notice how it slowly becomes less and less slippery.
And the whole halfcocked theory that you can change filter more often than oil needs to be shelved once and for all. There is a lot of microscopic particulate, as well as water + acids formed by combustion reactions, that an oil filter cannot remove but changing your oil can. I don't care how much teflon DuPont jizzed into each quart, or whatever dishonest claim to BeStEsT OiL EvAr!!11 info you've been reading, oil is disposable and dies quickly. Change it often.
Re: (MiraiZ)
120k mils on mine.. full syntech every 6-7k miles after turbo every 5-6k i use higher capacity filters and what ever teh top brand is.. for some reason fram has a bad rep but i have used fram's filters since day one. And im the original owner of my civic.
dyno oil do get changed every 3k if u run hard on them even often.. but syntechs are much much more dorable, breaks at a lower rate, is much resistan towards acidity and absorbing humidity.. but if you feel confortable changifn often much better for oil companies... here in teh US have been brain washed about frequent oil changes.. syntec oils are ok for 10k but dont listen to me, my family and i do belive in extended oil change.. by the way we r from europe were the mayority of people do the same thing...
cheers... .02
cheers... .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK »</TD></TR><TR><TD CLASS="quote">i change my oil every 1000 and filter
royal purple 5w30</TD></TR></TABLE>
me too
me too
Re: How often should oil be changed in turbo engines?? (BlueHatch00)
how does ur fuel gets on ur oil? maybe i dont get the relationship injectors/oil change..
Re: How often should oil be changed in turbo engines?? (saso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saso »</TD></TR><TR><TD CLASS="quote">the oil gets past the rings in to the oil, like washing the cyclinders.</TD></TR></TABLE>
come again??
come again??
I've got a 98 hatch with a ls/turbo. My engine management is haltech running stock injectors with two secondary 440 denso's. As for fuel, I've got the stock pump with a msd external pump. Stock rail, regulator and filter. I'm only pushin 9 psi through a garrett T3/T04 right now. I'll mainly be on the highway.
HT's Biggest Loser
Re: (BlkWido98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkWido98 »</TD></TR><TR><TD CLASS="quote">I've got a 98 hatch with a ls/turbo. My engine management is haltech running stock injectors with two secondary 440 denso's. As for fuel, I've got the stock pump with a msd external pump. Stock rail, regulator and filter. I'm only pushin 9 psi through a garrett T3/T04 right now. I'll mainly be on the highway.</TD></TR></TABLE>
Just change it every 2k to be safe..
