Help wierd whining sound.
Old Sep 3, 2003 | 07:46 AM
spike's Avatar
Default Help wierd whining sound.
Ok here's the problem.. when the car is in reverse it makes that wierd whining sound like all manual cars.. however now it does that when going forward also only louder .. only recently started.. car has been turbo for about 4 months.. and has an ACT clutch. Any ideas? Seems to only do it when it's in gear.. not when it's in neutral. thanks for any advice!
Old Sep 3, 2003 | 07:50 AM
93LSivic's Avatar
Default Re: Help wierd whining sound. (spike)
Not FI related, but I will try to help.
Try draining your trans fluid. Make sure you inspect the fluids color. Goldish will be work synchro rings, silverish will be worn bearings and/or gears.
Sounds to me like you could have a bearing issue. Since it only makes the noise while in gear I would rule out the pilot bearing and throwout bearings, but inspect those as well.
Old Sep 3, 2003 | 08:52 AM
civperc's Avatar
check your brake assembly/parts too. Something could be loose or angled and causing the strange whining.
soupE__
Transmission & Drivetrain
Dec 2, 2010 08:30 PM
peekeesh
Jun 1, 2010 07:52 AM
turbocivic0618
Apr 8, 2006 10:13 PM
pearl
Nov 8, 2004 05:28 PM
BudMan
Aug 11, 2004 04:58 AM
