What exactly controls boost?
Old Sep 2, 2003 | 05:48 PM
Hoodwinked's Avatar
Default What exactly controls boost?
Hey,
I have a question about boost. Many people say boost is not RPM dependent, it is exhaust flow dependent. Now what I dont understand is wide open throttle? What exactly is it? How does that relate to boost? Do I have to be at WOT to produce any boost? Thank you.
Old Sep 2, 2003 | 06:03 PM
JMinSi2000's Avatar
Default Re: What exactly controls boost? (Hoodwinked)
The wastegate controls boost.
Old Sep 2, 2003 | 06:04 PM
EJ1 wilcox's Avatar
Where to start?....
I'll try to explain it as simply as possible...
Exhaust gasses cause the turbo to spin, the faster it spins, the more air it pumps into the intake manifold and the more boost it produces. That said, it is somewhat RPM dependant because at higher RPMs exhaust gasses are coming out faster and spinning the turbo faster, thus creating more boost.
Did that make sense? I'm sure someone else can explain it better but I thought I'd give it a try!
Old Sep 2, 2003 | 06:12 PM
Cramerox's Avatar
Default Re: What exactly controls boost? (koreanwilcox)
i was thinking boost was more load dependent.
Old Sep 2, 2003 | 06:23 PM
vtec.dc2's Avatar
boost is load dependant.. if you apply enough throttle, you will start building boost, and you don't need to be at wot.. ho soon your turbo spools will depend on turbo specs (compressor and turbine size), so i till take longer for larger turbo to spool while smaller turbo can spool much earlier...
besides engine and turbo.. manifold, type of wastegate, intercooler and piping will play a role in how your car responds with boost..
maybe this will help too: http://auto.howstuffworks.com/turbo.htm
Old Sep 2, 2003 | 06:37 PM
MADEINIRAQ's Avatar
Default Re: What exactly controls boost? (vtec.dc2)
when desired boost is reached.. the wastegate bleeds off the exhaust so the turbo keeps a constant boost.
every other part indirectly affects boost.. but the wastegate controls it
Spaceballsthelunchbox
Sep 4, 2010 02:52 PM
r1lorenzini
Feb 19, 2004 11:54 AM
1990hondaHF
Aug 5, 2003 11:54 AM
incognitoracerr
Jan 10, 2003 05:42 PM
Integra187
Sep 21, 2001 07:13 PM
