Flex-a-lite fan install: fan wont kick on....
I just got done installing this fan http://store.summitracing.com/...2D110, it came w/ an adjustable thermostat, and a manual switch.
i hooked both up and did everything like it said. I even adjusted the thermostat all the way to cold, but after i drive for a bit the fan wont ever kick on, it only kicks on when i use the manual switch.
anyone installed one and used the adjustable thermostat that goes in the upper radiator hose? (it doesn't use the stock fan wires, it uses a different module)
thisdamnhonda
21
02-26-2012 09:47 AM
