Which intercooler to match half radiator?
Old Sep 1, 2003 | 02:39 PM
TAG's Avatar
TAG
Default Which intercooler to match half radiator?
I'm sure this idea has been thought of before, but after several searches I haven't seen mention of this...pls feel free to direct me to an existing H-T post.
Goal:
I'd like to run a C&R aluminum half radiator, and then find or make an intercooler which fills up the 2nd half.
Kinda like this...
This configuration would allow both heat exchangers to receive fresh ambient air, contrasted with the typical setup most of us use (intercooler in front of radiator).
Does any company make such an intercooler?
(or is there an OEM one off a stock car?)
Please post your opinions (with reasoning please) and more importantly, if anyone makes an intercooler in this "half radiator" size configuration
This is for a 90 CRX with Greddy turbo kit.
Thanks
Old Sep 1, 2003 | 02:46 PM
vtec65's Avatar
Default Re: Which intercooler to match half radiator? (TAG)
Im sure this has been done before using a side mount DSM intercooler Search for "side mount intercooler" and you can see what the IC looks like.
Old Sep 1, 2003 | 03:09 PM
TAG's Avatar
TAG
Default Re: Which intercooler to match half radiator? (vtec65)
I'm currently running with the 1g dsm smic you're referring to
....alas, these smics are a lot smaller than what I have in mind. In fact, mine is hidden in the bumper cavity where the stock resonator goes (below passenger headlight). These things are small
The intercooler I would want would be the same size (or nearly the same) as the C & R radiator.
Any ideas anyone?
Thanks
Old Sep 1, 2003 | 03:15 PM
nigel's Avatar
just go to the junk yard and search for an intercooler thats the right size. then go have new tanks welded on. cant be that hard.
Old Sep 1, 2003 | 04:12 PM
TAG's Avatar
TAG
Default Re: (nigel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel &raquo;</TD></TR><TR><TD CLASS="quote">just go to the junk yard and search for an intercooler thats the right size. then go have new tanks welded on. cant be that hard.</TD></TR></TABLE>
I'm trying to save myself from reinventing the wheel here. With all the H-T members out there, I'm hoping someone has already had some experience with this.
Last resort, of course, would be to hit the yards.
Old Sep 1, 2003 | 04:51 PM
int3gra's Avatar
Default Re: (TAG)
get a custom one made, ask earl or Arturbo.
Old Sep 1, 2003 | 05:02 PM
ScrapinSi's Avatar
get a custom one made, or go to a junkyard, and find yourself a turbo shadow/daytona/caravan... A t2 car had a radiator & Intercooler that bolted to each other....
Old Sep 1, 2003 | 06:07 PM
bob16ost's Avatar
i say use the DSM IC
Old Sep 1, 2003 | 06:32 PM
TAG's Avatar
TAG
Default Re: Which intercooler to match half radiator? (ScrapinSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">get a custom one made, or go to a junkyard, and find yourself a turbo shadow/daytona/caravan... A t2 car had a radiator & Intercooler that bolted to each other.... </TD></TR></TABLE>
I didn't know that. Now I know which cars to look for at least. Thanks..pretty interesting btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Int3gra &raquo;</TD></TR><TR><TD CLASS="quote"> get a custom one made, ask earl or Arturbo.</TD></TR></TABLE>
Thanks...I'll follow up with them.
Thanks guys..
Old Sep 1, 2003 | 06:44 PM
PHiZ's Avatar
Do a search on ebay for intercooler, you'll get some ideas, maybe a saab intercooler, or an RX-7... Good luck!
Also, remember when plumbing, avoid too much turning...
-PHiZ
Old Sep 1, 2003 | 07:04 PM
GSRswapandslow
Guest
Posts: n/a
i was going to do that.....
but, i'm just going bling spec front mount y0
the dsm stuff isn't that bad though. i mean...it can get heavy *** eclpises into the 13's easily
well, maybe a supra side mount?? the ones on the MK4 are pretty big, right?
B18C_EJ8
Oct 6, 2007 06:19 PM
Seanyriver04
Sep 8, 2007 11:44 AM
powerdbygarrett
Jun 9, 2007 03:30 PM
Corruption
Apr 23, 2005 10:17 AM
