detonation amplifier diy article
i dont know if anyone has seen this article,but i figured i'd post it in fi since detonation kills boosted motors rapidly
http://www.autospeed.com/cms/article.html?&A=0353
It's kind of discouraging to read the previous article to that one that says that the J&S Safegaurd "doesn't work terribly well" I think I'm going to go buy a whisper 2000, save myself 350$
Thats what I was thinking.
My friend has a junkyard setup on his toyota corolla. FMU and high pressure pump for fuel management. He has cracked ringlands three times this summer.
He dosn't mind too much, each piston is only 15 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blusi »</TD></TR><TR><TD CLASS="quote">It's kind of discouraging to read the previous article to that one that says that the J&S Safegaurd "doesn't work terribly well" </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Overall the Safeguard didn't work terribly well, the salesman - probably quite correctly - suggesting that the particular knock sensor being used wasn't a good match for the engine.</TD></TR></TABLE>
Yeah i went to order right after reading the article, and ran into the same problem. If you look the article is written in 1999, which means the catalog numbers have changed since that time period. They dont seem to carry the Whisper 2000 anymore, but I am sure its available on the internet.
i ordered the kit and i have yet to assemble it. Its a great idea. Good luck hearing anything if you are at a shop with a roller dyno.
you will need some very large clips to attach that piezo sensor that they give you.
You ordered the whisper 2000 kit? And why would it not work? Snap on makes some electronic ears that work very well for this sort of thing.. They are just more expensive and lot more fancy.. they have six clamps.. So Jeff you didn't end up buying one then? If you find it please let us know.
Tod
Tod
I found the link, got the part numbers, then posted back on here. I started putting the part numbers into the website to order them and they didnt recognize them, which means they probably dont carry the items anymore.
you can probably use on of these
http://www.radioshack.com/prod...D1121
i also found about 4 of these whisper 2000s on ebayhttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3044612399&category=32 81
omar
omar
Pioneer162
Jun 18, 2007 07:08 PM
gnat
Apr 16, 2006 09:00 PM
