Cel Code 3 with AFC hack and way too much fuel
Old Sep 4, 2003 | 09:55 AM
jetpilot's Avatar
Default Cel Code 3 with AFC hack and way too much fuel
Me and a friend just ended installing a turbo kit on a d16y7. We are using the AFC, DSM 450 and 255lph fuel pump. We wired everything as the instructions said and have set the fuel substraction from -%40 to even -%50 but when we try to turn on the car it just bogs and wont start. We are getting a cel code 3 which is MAP sensor electrical failure. What could it be? To low of a map signal? We are at about 1000 meters above sea level (dunno in feet). Could the rail be getting too much fuel pressure that the stock regulator cant cope with and thats wy it wont even idle?
Old Sep 4, 2003 | 10:06 AM
boosted_dc2's Avatar
Default Re: Cel Code 3 with AFC hack and way too much fuel (jetpilot)
are you runing a resistor box on the injectors??? do you get the code while your driving or is it just when you idle???
Old Sep 4, 2003 | 10:12 AM
luckypon7's Avatar
i have a b18c1 with rc 440 and afc, got in a wreck. i thought i won't get it back so took off the afc. so you know it was running way rich but it started up. if it doesn't start it can't be your fuel system i would think.
Old Sep 4, 2003 | 10:15 AM
senpai's Avatar
I'd re-check VAFC install
Old Sep 4, 2003 | 04:54 PM
jetpilot's Avatar
we got the car to half-idle and kinda-run but we had to put in 310cc injectors from a mitsubishi 3000 VR-4 cause it didnt want to idle or even start with the 450s. The afc install is fine, we checked everything and everywire from the afc and injectors (were using inline 10watt 10 ohm resistors)
Now our bigest proble is that the turbo TD05H 14b is smoking like a bitch and theres even oil coming out of the downpipe
Old Sep 4, 2003 | 05:58 PM
SOFLSOL's Avatar
check your oil pressure to the turbo. Check and see if your getting voltage from the map.
Old Sep 4, 2003 | 06:54 PM
jetpilot's Avatar
yes we chocked the map voltage and its fine.
How do I check the oil pressure to the turbo? Will it damage the seals if it has too much? Its coming from a line from a tee in the back of the block where you connect the oil pressure sensor
Old Sep 4, 2003 | 07:03 PM
dirty-t's Avatar
Default Re: (jetpilot)
code 3: rich beyond what ecu can handle. change your settings on your afc and see if that helps..im just going off of what i read last night on homemadeturbo.com i belive they said u can allso retard your timming slightly to trick the ecu..read this... http://www.homemadeturbo.com/f...=4383
its a very help full thread if u need to know how to tune your afc or need to know how it works for that matter
Old Sep 4, 2003 | 07:05 PM
dirty-t's Avatar
Default Re: (dirty-t)
that link didnt work sorry...
Old Sep 4, 2003 | 07:17 PM
Infinity_Racer's Avatar
are you sure your wiring is correct for the afc? how about your other settings? i remember i connected the wires backwards and it had the same symptoms as youre having now....
OFF TOPIC: will more oil than what is needed in the engine (in the oil pan) increase oil pressure?
Old Sep 4, 2003 | 08:37 PM
hollaback6's Avatar
did you make sure and set your ecu to pressure?
si90rex
Feb 14, 2010 11:59 AM
JDMB20TDA
Sep 11, 2007 02:54 PM
wheelmaneg6
Oct 31, 2006 03:45 PM
vietxdragon
Sep 13, 2006 01:40 PM
Starscream
Sep 3, 2003 10:05 PM
