Going turbo. was wondering if I should sell my current all motor head or keep it for the turbo proje
Hey everybody. I have finally decided to go turbo. At first, I chose to go the all motor route, but have decided that it wasn't quite up to my expectations for the kind of cash I was shelling out. I currently have a stock gs-r block with p&p head, itr cams, portflow vavletrain, skunk2 intake manifold+cam gears, aem FPR, with plans for a hondata s200, 310 or higher injectors, and new ecu.
I was wondering if you guys thought i should get a new head? or do you think it would be fine to just turbo it with the current head? I was thinking about changing out the pistons, but do you guys think it would be fine to turbo it in the current configuration? Thanks for all your input, and appreciate your help!
Re: Going turbo. was wondering if I should sell my current all motor head or keep it for the turbo p
that head should be just fine with that mani also
but if you want a stock gsr head let me know i have 2 exta's
You're probably going to want to swap out the cams for some stock GS-R cams. The R ones have too much overlap... other than that, it's all good.
lose the cams
get bigger injectors
get boost upgrade on hondata
youll be good
youll be good
