install problems need help bad!!!!!
Old Sep 3, 2003 | 12:54 PM
boost fed ls's Avatar
Default install problems need help bad!!!!!
well i am in a holt with my turbo install. i have a drag mani and a t3/t04e on an integra ls and i still cant get it to fit. hacked most of the webing and still no fit. any ideas?
_______
Old Sep 3, 2003 | 12:56 PM
DaveF's Avatar
Default Re: install problems need help bad!!!!! (jdm2916)
did you rotate the compressor housing?
Old Sep 3, 2003 | 01:03 PM
Default Re: install problems need help bad!!!!! (2.2Lcivic)
yes i did its touching the back of the block
Old Sep 3, 2003 | 01:06 PM
TeStUdO's Avatar
you cant cut the webbing anymore???
Old Sep 3, 2003 | 01:08 PM
igotyofire's Avatar
is it the 4bolt or 5bolt pattern?
Old Sep 3, 2003 | 01:23 PM
Default Re: install problems need help bad!!!!! (igotyofire)
no i cant cut it anymore its not hiting the webing any more it touching the back of the block, and its a 4 bolt turbo
Old Sep 3, 2003 | 01:39 PM
DIRep972's Avatar
Smarter than you
Read this- https://honda-tech.com/zerothread?id=402894
It can be made to fit w/ a Revhard/inline pro but you gotta shave the crap out of it. Im not sure about w/ a drag.
Old Sep 3, 2003 | 01:56 PM
quikB18B's Avatar
Default Re: install problems need help bad!!!!! (DIRep972)
Yeah ive been seeing problems with the drag manifold/fitment, I got lucky and didnt even have to shave any webbing on my inlinepro/sc34 combo.
Have you tired angling to compressor outlet slightly toward rear of car. Mine is sitting @ a 10 degree angle. Try playing with the fitment and angles to squeeze it in there .
Old Sep 3, 2003 | 02:05 PM
Default Re: install problems need help bad!!!!! (quikB18B)
yes i will try to play with the turbo. if i got a plate of steel cut like the flange and put two gaskets on it do you think it would work? it bolts fine on the top part its just the bottom, all i need is like an 1/8 of an inch clearance to make it fit
Old Sep 3, 2003 | 02:11 PM
quikB18B's Avatar
Yeah i have heard of people using gaskets, or a thicker metal gasket to free up some room. I say try that, it may be your only option.
Old Sep 3, 2003 | 02:17 PM
thanks for all of your help
Old Sep 3, 2003 | 07:47 PM
scatuli's Avatar
or if you want you can order the exhaust manifold flange from cheapturbo.com
then take out the existing studs and put some bigger ones in if you want or you could use boltsand use it like a gasket but with gaskets of course
Bictorious
Feb 29, 2004 06:17 PM
boost fed ls
Jul 27, 2003 09:07 AM
turbo2000
Jul 1, 2003 06:15 AM
InTeGrA B18b1
Apr 10, 2003 05:29 PM
CM-R
Oct 10, 2001 11:53 AM
