Black smoke at Idle...Help!!!
Old Sep 1, 2003 | 11:03 AM
TurboJesse
Guest
Posts: n/a
Default Black smoke at Idle...Help!!!
Lately evertime i start my car (car has never been driven, runnig hondata s100 with basemap) it dumps excessive black smoke @ idle and if i touch the gas slightly, It also has trouble holding an idle and will die out if i dont' give it some gas, Im very confused, the first time i started the car up after the install with hondata it started perfect, no smoke, held a nice idle, etc...it has went downhill everytime from there. BTW i have replaced the plugs a few times.
Old Sep 1, 2003 | 11:11 AM
HXMan's Avatar
Default Re: Black smoke at Idle...Help!!! (Mpir3)
Sounds like its running too rich. Perhaps the basmap is wrong?
Old Sep 1, 2003 | 11:19 AM
TurboJesse
Guest
Posts: n/a
Default Re: Black smoke at Idle...Help!!! (HXMan)
im not sure, thats what i thought too, but when i first installed the hondata the car started and idled fine, no smoke, what so ever
Old Sep 1, 2003 | 11:38 AM
TurboJesse
Guest
Posts: n/a
Old Sep 1, 2003 | 01:54 PM
TurboJesse
Guest
Posts: n/a
Im wondering if not having the o2 sensor hooked up could cause this? the car is def running extremely rich, Its just really confusing since it ran fine before the first few times i started and now without changing a thing it runs like ****.
Old Sep 1, 2003 | 02:29 PM
boosted hybrid's Avatar
What was the ambient temperature when you started the car the first few times compared to the temperature now? Do you have a fpr? Its a possibility your fuel pressure got turned up. The hondata base maps are quite good for the idle, its very possible that it needs some tweaking to get it right. If its black smoke, then its fuel.
Old Sep 1, 2003 | 02:56 PM
TurboJesse
Guest
Posts: n/a
Default Re: Black smoke at Idle...Help!!! (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">What was the ambient temperature when you started the car the first few times compared to the temperature now? Do you have a fpr? Its a possibility your fuel pressure got turned up. The hondata base maps are quite good for the idle, its very possible that it needs some tweaking to get it right. If its black smoke, then its fuel.</TD></TR></TABLE>
it was very hot and humid the week i first got it running (not sure exact temps) now its been rainy and colder..I just have a stock FPR, It was perfect @ idle the first 4-5 times i started the car up and has worsened ever since.
Old Sep 1, 2003 | 03:12 PM
MiraiZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">Im wondering if not having the o2 sensor hooked up could cause this? the car is def running extremely rich, Its just really confusing since it ran fine before the first few times i started and now without changing a thing it runs like ****.</TD></TR></TABLE>
um...yeah....try putting the o2 sensor back
Old Sep 1, 2003 | 03:20 PM
TurboJesse
Guest
Posts: n/a
Default Re: Black smoke at Idle...Help!!! (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">
um...yeah....try putting the o2 sensor back </TD></TR></TABLE>
Yea im hoping that makes a little difference, but i didn' t have it in before and it still ran fine at first..
Old Sep 1, 2003 | 06:23 PM
TurboJesse
Guest
Posts: n/a
Bump for the nite crew
Old Sep 1, 2003 | 11:18 PM
lazerus's Avatar
Black Smoke = Rich burning condition
Blue Smoke = Oil burning condition
Dissapearing White smoke = Water vapor and perhaps coolant burning also.
jnk111
14
Feb 21, 2012 11:30 AM
attack666
Sep 27, 2011 01:52 PM
TurboJesse
Sep 1, 2003 01:12 PM
B00ST2nR
Mar 2, 2003 10:44 PM
