equal length manifold oil return setups... help
Old Sep 4, 2003 | 11:13 AM
Mr. Softee's Avatar
Default equal length manifold oil return setups... help
how are you epople doing this? my return line is like 2.5" long and i have a tinky kink in it. I took another piece of hosing and kinked it the same way and oil still flows through it just fine so its not blocked off or anything but I still do not like it this way. anyone have any pics? Im using the standard return flange, a 45 degree male to male off of it, to a 2.5" earl's -10 line which goes to a straight bung in my pan.
Old Sep 4, 2003 | 11:49 AM
Overblown-Teg's Avatar
Default Re: equal length manifold oil return setups... help (94goldjungsr)
I think thats how I did mine.. I was able to angle the fittings in a way that kept the line from kinking..Make sure that teh kink is not from when you tightened the hose fitting and the hose twisted. You might try using two wrenches to hold it still.
Old Sep 4, 2003 | 12:20 PM
Full-Race Geoff's Avatar
it might be that your bung is located in a bad spot on the oil pan... it might make much more sense to weld on a new bung.
Old Sep 4, 2003 | 12:34 PM
*Boostwerks*'s Avatar
Here's a pic of my setup...
I've yet to run it, but I doubt I will have any problems. It's completly down hill from the fitting on the turbo to the fitting on the pan. This was the only way I could find that wouldn't cause the ss line to kink.
Bryson
Old Sep 4, 2003 | 01:51 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">how are you epople doing this? my return line is like 2.5" long and i have a tinky kink in it. .</TD></TR></TABLE>
You only need 2.5" of the return line ? that's kinda short in a way. It's hard to get 2.5" of line to bend. My suggestion is to try to use a longer line to route it. As long as the line is going downhill, longer versus shorter line is not too significant.
stan
Old Sep 4, 2003 | 02:33 PM
g2turbo's Avatar
Default Re: equal length manifold oil return setups... help (Flamenco-T)
anybody have any more pics on their FR setup with the oil return?
Old Sep 4, 2003 | 03:02 PM
Full-Race Javier's Avatar
watch out for those oil guage pressure lines
Old Sep 4, 2003 | 03:54 PM
Mr. Softee's Avatar
Default Re: equal length manifold oil return setups... help (javierb14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by javierb14 &raquo;</TD></TR><TR><TD CLASS="quote">watch out for those oil guage pressure lines </TD></TR></TABLE>
Old Sep 4, 2003 | 06:12 PM
rOby's Avatar
if u used swivel fittings i think ur problem may go away
Old Sep 5, 2003 | 06:30 PM
Mr. Softee's Avatar
Default Re: equal length manifold oil return setups... help (rOby)
well im just gonan keep mine slightly kinked my oil seals are fine and its clearly flowin so dont fix it if it aint broke.
Old Sep 5, 2003 | 06:52 PM
Turbocivic94's Avatar
Default Re: equal length manifold oil return setups... help (Bryson)
what's ur setup if u dont mind me asking?
Old Sep 5, 2003 | 07:57 PM
Mr. Softee's Avatar
Default Re: equal length manifold oil return setups... help (25 PSI CRX)
search back on my name a little.
Old Sep 18, 2003 | 08:09 PM
tegasaurus's Avatar
i've only heard the story of sam making a lone boost run and being scalded with boiling hot oil, midevil style haha
CTR_B
Apr 15, 2008 11:00 AM
greasemonkee
Jul 23, 2007 06:20 PM
D15Bbigred
Mar 1, 2007 07:36 PM
Fatty_1775
Jul 30, 2006 08:04 PM
stizzit
Sep 16, 2004 09:17 AM
