Car shut off after boosting!!
Old Sep 3, 2003 | 07:11 AM
billk2k's Avatar
Default Car shut off after boosting!!
A little bit ago I was driving my car and I boosted about twice (not even full boost). My check engine light came on and the a/f guage on my car read very lean and the car started to sputter when not running boost. I went to turn in the turn lane and the car shut off. I turned the car off completely and the car started again fine with no problems. What could be causing this problem because this could get very annoying.
Old Sep 3, 2003 | 08:05 AM
boosted_dc2's Avatar
Default Re: Car shut off after boosting!! (billk2k)
what engine code is it throwing, thats probably a good place to start
Old Sep 3, 2003 | 08:09 AM
billk2k's Avatar
Default Re: Car shut off after boosting!! (hooked_up_gsr)
I dont know I have not had a chance to look yet. It just happened to me when I was on my way to work. For some reason the car started running very lean (probably in limp mode) and started hesitating a lot. Could it be the old injectors in the car not giving the car enough fuel?
Old Sep 3, 2003 | 07:50 PM
scatuli's Avatar
my friend had that same problem it was his ground if i were you i would double check it just my 2 cents
Old Sep 3, 2003 | 07:55 PM
80884's Avatar
Default Re: Car shut off after boosting!! (scatuli)
MAP sensor code? my friends teggy did that and that was the code. don't know 100% why but thats the same thing it did to his car.
Old Sep 3, 2003 | 07:57 PM
spun Vtec's Avatar
Default Re: Car shut off after boosting!! (80884)
its the map i bet
Old Sep 3, 2003 | 08:41 PM
Teg4e's Avatar
Default Re: Car shut off after boosting!! (spun Vtec)
i have this exact same problem a few times in the past year, cept it just runs bad but doesn't actually die. The code that comes up is MAP sensor. Everytime after I restart it though, it works like normal, so it's not a big deal.
Old Sep 3, 2003 | 09:16 PM
R6Elmo's Avatar
Default Re: Car shut off after boosting!! (Teg4e)
i'm sure you aren't actually going lean, but possibly your 02 sensor or the voltage from the 02 sensor is going in error. Check your plugs to be more certain though.
Check the code and hopefully that can lead you somewhere. The fact that restarting the car erases the problem points to something the ecu is detecting. check your harnesses and make sure all your sensors are working okay.
Old Sep 5, 2003 | 04:20 AM
scatuli's Avatar
Default Re: Car shut off after boosting!! (R6Elmo)
if you think it is your map sensor you can test it with a voltmeter find the signal wire and it should read 1.3-1.4 volts ish you will know when you find it it is the only one similar to that number then give it some gas at idle and the number should go up quite a bit.
Old Sep 5, 2003 | 05:17 AM
billk2k's Avatar
Thanks for all of you suggestions so far. I talked to the guy at DRAG and he said that the MAP Bypass Valve could be bad and gave me a way to check that out. If this is the case, that should solve most of the problems. I will have to wait for the weekend to try it out.
calcamaro
Jul 15, 2018 01:56 PM
ReFracture
Mar 24, 2013 03:41 PM
blaze.1
Sep 24, 2009 11:04 AM
teknikEG6
Apr 15, 2006 03:04 PM
