Dyno Results!
Had my car dynoed this last week at Church Automotive Testing. I was very surprised at the numbers that I put down. Here's the setup:
stock ls engine, t3/t4 garret 57 trim turbo, 2.5 inch flared to 3 inch dp, 3 inch exhaust, revhard manifold, hondata s100, 440cc precesion injectors, stock intank fuel pump, and inline fuel pump.
At 7 psi the car put down 226 whp and 182 tq and at 12 psi the car put down 289 whp and 222 tq. Shawn did a great job tuning the car. What do you guys think?
Thanks, it was a combination of good parts and great tuning by shawn. The car was on the dyno for about 3 hours. Most of which was part throttle tuning. This was done on a dynapack dyno. These dynos allow you to do the part throtle tuning because it allows you to put a set load on the engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-sohctec »</TD></TR><TR><TD CLASS="quote">Awesome numbers!
If you put the right components together you can make a ton of power, even WITHOUT vtec, all you need is PSI!!!</TD></TR></TABLE>
i agree
i agree
The car hit full boost at 4000-4100 rpms at 12 psi. It started to spool at like 1800 I believe. Shawn is going to send me the boost graph and I'll take a lot at it to double check. I didn't get a chance to compare the full 2.5 inch dp vs. the flared because this was my first time at the dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete »</TD></TR><TR><TD CLASS="quote">The car hit full boost at 4000-4100 rpms at 12 psi. It started to spool at like 1800 I believe. Shawn is going to send me the boost graph and I'll take a lot at it to double check. I didn't get a chance to compare the full 2.5 inch dp vs. the flared because this was my first time at the dyno. </TD></TR></TABLE>
damn you start spooling at 1800k!! damn i start at 3.5k!! you must either have a ball bearing turbo or a .57 or smaller a/r.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">
damn you start spooling at 1800k!! damn i start at 3.5k!! you must either have a ball bearing turbo or a .57 or smaller a/r.</TD></TR></TABLE>
me and yang are slow spoolers whats your secret haha
