does the afc II really advance timing
Old Aug 31, 2003 | 02:50 PM
darylfiend11's Avatar
Default does the afc II really advance timing
i have a afc but i have not installed it yet i was using the very helpful search function that is located in the upper right hand corner and i read that the afc will advance ignition and cause detonation but then i heard so many people saying that it has done wonders so assuming it is hooked up correctly will it advance the ignition or cause detonation and would it be a good idea to use with the uberchip?
thanks
Old Aug 31, 2003 | 03:39 PM
Default Re: does the afc II really advance timing (darylfiend11)
anybody??
Old Aug 31, 2003 | 03:59 PM
DigitalFusion's Avatar
it doesnt touch timing
Old Aug 31, 2003 | 05:05 PM
Joseph Davis's Avatar
Default Re: (CustomCockpits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CustomCockpits &raquo;</TD></TR><TR><TD CLASS="quote">it doesnt touch timing</TD></TR></TABLE>
Wrong.
Do a search, I'm sick of explaining this.
Old Aug 31, 2003 | 05:10 PM
booscivic's Avatar
Yes it does!!!!
Old Aug 31, 2003 | 07:41 PM
boosted hybrid's Avatar
Default Re: (booscivic)
The afc hack does per say advance the timing, but it alters the way the ecu reads the map sensor. When the engine is seeing 8psi, its saying that the computer is at wot/atmospheric conditions or 0psi/0 vacuum. The ecu reads the corresponding timing value which is 30-32 degrees advance, when the engine should really be seeing 26-27 degrees total advance. It doesnt advance the timing, it inhibits the ecu from pulling back the timing since it thinks the engine is operating in atmospheric conditions/0 vacuum.
Old Aug 31, 2003 | 08:23 PM
Default Re: (boosted hybrid)
boosted hybrid is correct about NA WOT final timing and ideal timing at the theoretical boost level, 8 psi, he is talking about.
I'm talking about how the Honda ECU thinks you are on (in boosted hybrid's terminology) part throttle spark plateau in the lower boost figures... 38-44 degrees depending on your flavor of ECU.
Old Aug 31, 2003 | 08:33 PM
well krud...
I was under the impression that it was a FUEL ONLY computer, an did not touch timing. Which, in a way is true, but from what you guys are saying, thats exactly the problem, it doesnt let the ECU retard it.. right?
Modified by CustomCockpits at 11:47 PM 8/31/2003
Modified by CustomCockpits at 11:49 PM 8/31/2003
Old Aug 31, 2003 | 09:45 PM
AFC tweaks MAP sensor signal.
Honduh ECU fuel/ignition maps are in RPM vs MAP table form. So, you alter fuel, you alter ignition.
It doesn't matter so much in a NA ride where the fuel is very close and you only need to alter a few % to get fuel in line... with ignition curve deflection of less than a degree... but when you start slicing huge chunks off the MAP signal the ignition deflection gets pretty substantial.
vadersi
Feb 27, 2005 08:47 AM
the.hamburglar
Oct 14, 2004 11:37 AM
aron0903
Aug 4, 2004 12:34 AM
VSM EXtasy
Jul 19, 2003 10:19 AM
BlueSi2k
Nov 18, 2002 01:31 PM
