Cylinder Leak down Tester Kits
Re: Cylinder Leak down Tester Kits (GudeH23a)
Re: Cylinder Leak down Tester Kits (Foozball26)
Yes, quality is never cheap. But sometimes I am. Does anyone else have any 411 on the kits?
Re: Cylinder Leak down Tester Kits (Paul_Vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paul_Vang »</TD></TR><TR><TD CLASS="quote">summit has one for like 60-70 bucks</TD></TR></TABLE>
Are their leakdown testers just as good and accurate as other brands?
Re: Cylinder Leak down Tester Kits (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg »</TD></TR><TR><TD CLASS="quote">
Are their leakdown testers just as good and accurate as other brands?</TD></TR></TABLE>
im no expert but ide say for the average garage it would be fine...only way i would spend the money for a snap-on or similar is if i had a shop or used the tester very frequently
Re: Cylinder Leak down Tester Kits (gritsak)
I use the tavia tester that summit sells. I have no problems with it. It's great. There's just a difference in gauges so I add 2 psi to get my leak percent.
Re: Cylinder Leak down Tester Kits (mskibbz-T)
Got one off ebay. Paid only 50 bucks plus shippings. Nice quality with 2 oil-filled gauges. I was very satisfied and it was very accurate.
Moderator in Chief
I use the Summit one. That Snap On one is BS.. $295 for the same friggin thing, get out of town. However the Snap On one does come with a nice pretty case lol. Actually unless you really care about % compression lost you dont even need the tester.
If your just looking for where compression loss is occuring (ie testing valve seal, rings, or headgasket) you just need a compressed air source, and a hose with a spark plug adapter to screw into the spark plug sockets (comes with leakdown and compression testers). In cases like that % loss is irrelevant, you just want to see/hear where the air is escaping.
1996_civic_Coupe
61
08-16-2008 09:11 AM
hrs-parker
05-17-2008 01:15 PM
