what size turbo should i run???
i am lookin for a good size turbo to run on my 95 ls block. my goal is about 250 @WHP @ about 12 psi stock b18b engine. would a t3/t04-e(i hope i said it right) be too big if so then what turbo should i run, i am also still undecided if i should run hondata or afc hack so any suggestions and info would be cool....
thanks
cliff
thanks
cliff
Re: what size turbo should i run??? (25 PSI CRX)
but will boosting that big of a turbo what will full boost hit at?????with stock internals??????will i be safe boosting at 12 psi also with hondata or afc hack????i will be using 2 headgaskets with arp headstuds too but also lookin into what size injectors should i use.....
Re: what size turbo should i run??? (dragboy)
Spool time may be a problem on an LS engine with that big of a turbo....I think you're looking at 5000-5500ish 'til you reach full...I think most LS guys run t3/t4b .48 AR
Re: what size turbo should i run??? (BlueHatch00)
so a t04b will spool faster, but wont make as much power as t04E compressor would? is what it sounds like your saying?
Re: what size turbo should i run??? (igotyofire)
Man, If I were you I wouldn't get the T3/T4 hybrid. It does take a long time to spool. With my F23 engine(stock with 140 hp 140 Tq) full boost comes in at 4,000 rpms. Any rpm below that is SLOW as hell. Its bearable on my engine...I just need to learn to keep revs up...but your engine is smaller...i dunno.
