Compression Q
Old Sep 1, 2003 | 05:37 AM
swlabhot's Avatar
Default Compression Q
I'm building my B18C6 soon and what I like to know is if I put in 9:1 or 9.5 comp pistons in what would be the effective compression if the head gasket is oem? The stock compression right now is 11:0 on stock block.
Another thing, what compression do the JE's come in?
Old Sep 1, 2003 | 05:59 AM
MiraiZ's Avatar
Default Re: Compression Q (swlabhot)
the piston compression number is usually calculated using stock block, head, and gasket...so to answer your question, 9:1 would be 9:1 and 9.5 is 9.5...if you use stock thickness and you should be ok
Old Sep 1, 2003 | 06:54 AM
swlabhot's Avatar
Default Re: Compression Q (MiraiZ)
So if I use 9:5 pistons I can further bring the compression down with a thicker head gasket right? How does the thickness of the gasket ratio relate to the drop/increase in comp (i.e 0.5mm thicker equates to -1 drop in comp)?
Anyone knows the comp that the JEs come in?
TIA
Old Sep 1, 2003 | 10:51 AM
swlabhot's Avatar
The JEs come in 9:1 and 12.5:1 if I'm not mistaken....?
eg:R
Aug 8, 2008 02:58 PM
kazino42
May 22, 2005 02:41 PM
2kflamedlude
Apr 25, 2004 06:01 AM
JDM 007
Jan 24, 2003 01:08 PM
