Strengthening D series transmissions
Old Sep 3, 2003 | 10:09 AM
soundman's Avatar
Default Strengthening D series transmissions
Is there an after market transmission or can I purchase stronger gears for my SI tranny? I want to run 270 horse, but I'm afraid that it will break.
Old Sep 3, 2003 | 10:40 AM
5thgencivic's Avatar
Default Re: Strengthening D series transmissions (soundman)
Put in a quaife LSD and it will hold. Honda tranny's can handle... The diff is mainly the weak point(and synchros). Just my $.02
Old Sep 3, 2003 | 10:56 AM
Happyman's Avatar
Default Re: Strengthening D series transmissions (5thgencivic)
Someone was running 300 whp on a stock d series on here. I think it was BoostedED9 and I think the only reason his motor blew was due to cooling problems. Anyway, the d series tranny should hold up at 270 whp.
Old Sep 3, 2003 | 11:40 AM
Civic TSI's Avatar
Default Re: Strengthening D series transmissions (Happyman)
Pushing more than 300whp and so far so good. Diff is the weak point. If you can, get a 96+ Si tranny, the forks are made of steel instead of aluminium.
Old Sep 3, 2003 | 12:07 PM
RyanEJ8's Avatar
Default Re: Strengthening D series transmissions (Civic TSI)
Civic TSI you were running open diff?
It's not how much power you make but more so the traction you get. If there's no slippage in the tires or clutch is when you are more likely to break diffs. ex: slicks and a race clutch can sometimes = broken tranny
Old Sep 3, 2003 | 12:52 PM
Civic TSI's Avatar
Default Re: Strengthening D series transmissions (RyanCivic2000)
No, I'm using a Quaife.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">It's not how much power you make but more so the traction you get</TD></TR></TABLE>
True but even though I spin, I still manage to pull 1.77 60'. I've never break an Si tranny, beside some worn synchros.
Old Sep 3, 2003 | 12:57 PM
ELSpool's Avatar
do I dare ask how much an LSD runs?
Old Sep 3, 2003 | 12:59 PM
Default Re: (ELSpool)
Quaife=around $810
Old Sep 3, 2003 | 01:25 PM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic TSI &raquo;</TD></TR><TR><TD CLASS="quote">Pushing more than 300whp and so far so good. Diff is the weak point. If you can, get a 96+ Si tranny, the forks are made of steel instead of aluminium.</TD></TR></TABLE>
You mean 96-00 EX tranny.
Old Sep 3, 2003 | 02:05 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">
You mean 96-00 EX tranny.</TD></TR></TABLE>
It is Si in Canada and that is where he is from.
Old Sep 3, 2003 | 02:23 PM
M.A.R.C.'s Avatar
Default Re: Strengthening D series transmissions (ladysman)
oooo maybe i should get my 00 y8 tranny rebuild then. stupid 2nd gear is fux0r3d
Old Sep 3, 2003 | 06:18 PM
ross1459's Avatar
what about the old ZC tranny? are they too weak to consider? i was thinking about running one just for its close ratios. otherwise, is it possible to pull the gears and re-gear a y8 trans to the ZC specs?
Old Sep 3, 2003 | 06:43 PM
soundman's Avatar
Yeah I don't have the money to throw down on a LSD. I am going to be doing a major engine overhaul, so I am going to get at least the syncros replaced. So I can just swap out my forks for the 96-00 EX forks? What's a good axle and half shaft to use. I figure that those wont like 270 hp too much.
Old Sep 3, 2003 | 07:49 PM
Default Re: (soundman)
Gator Stage 2's..
Old Sep 3, 2003 | 07:56 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I don't have the money to throw down on a LSD. I am going to be doing a major engine overhaul, so I am going to get at least the syncros replaced. So I can just swap out my forks for the 96-00 EX forks? What's a good axle and half shaft to use. I figure that those wont like 270 hp too much.</TD></TR></TABLE>
Forks won't swap.
Old Sep 3, 2003 | 08:00 PM
spun Vtec's Avatar
Default Re: (RyanCivic2000)
i wouldnt be to sure if anything zc would go into this y8 tranny either
Old Sep 4, 2003 | 10:33 AM
soundman's Avatar
So to get the beter tranny, I would have to swap to hydrolic clutch, and put the EX tranny in? How much have all of you had your axles to?
Old Sep 4, 2003 | 11:43 AM
xci_ed6's Avatar
maybe you could modify the forks to fit?
-Dustin
Old Sep 4, 2003 | 11:44 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">So to get the beter tranny, I would have to swap to hydrolic clutch, and put the EX tranny in? How much have all of you had your axles to?</TD></TR></TABLE>
Yes you need to get hydrolic clutch and 96-00 EX tranny would be the best choice. I had my axels to 180WHP and broke one with some wheel hop.
Old Sep 4, 2003 | 12:28 PM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Yes you need to get hydrolic clutch and 96-00 EX tranny would be the best choice. I had my axels to 180WHP and broke one with some wheel hop.</TD></TR></TABLE>
Then just grab some Pep Boys with Lifetime warrenty lol Or those gator axels were looking mean that were up here a little while ago.
Old Sep 5, 2003 | 03:43 AM
soundman's Avatar
Where can I find those gator stage 2 axles, I tried searching. Am I just stupid?
Old Sep 5, 2003 | 03:52 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundman &raquo;</TD></TR><TR><TD CLASS="quote">Where can I find those gator stage 2 axles, I tried searching. Am I just stupid?</TD></TR></TABLE>
YOu didn't try hard enough.
https://honda-tech.com/zerothread?id=579042
Old Sep 5, 2003 | 09:35 AM
soundman's Avatar
Yeah so I'm just stupid.... How hard is it to switch to a hydrolic clutch, and is it worth my time? Does the mounts still work?
What do you guys think about these axles?
http://cgi.ebay.com/ebaymotors...46098
Modified by soundman at 1:55 PM 9/5/2003
Old Sep 5, 2003 | 09:56 AM
TurbodCX's Avatar
D- series tranny's suck!!
I just blew my tranny.
When i took it apart, two of the shift forks were broke, and the pin going through the dif, was also all fucked up. i ended up having to buy a new trans, and just start all over with all new seals and bearings.
The shift forks have to be the weakest point in the 92-95 D-series trans.
Be easy on them!!
Brian
Old Sep 5, 2003 | 09:59 AM
boosted hybrid's Avatar
I picked up a 99 ex tranny for 100.00 locally, they are super cheap and def. not worth the hassle to swap out the shifter forks. If you arent launching at the track, the stock transmission wont break on you. I was going to go with a quaife in the ex tranny, but most of the racing will be on the higway with the set-up anyway.
