jrsc problem O2 code
Old Sep 3, 2003 | 04:55 PM
94jaxgsr's Avatar
Default jrsc problem O2 code
I have a 94 gsr with a jrsc on it running 8lbs with 3 inch exhaust with no cat i have replace my O2 sensor but the car is still throwing a code for the O2. has anyone run in to this problem before? i reset the ecu plenty of times and it still came on.
Old Sep 3, 2003 | 05:02 PM
MooreBoost's Avatar
Default Re: jrsc problem O2 code (94jaxgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94jaxgsr &raquo;</TD></TR><TR><TD CLASS="quote">with no cat</TD></TR></TABLE>
You need an o2 fooler.
gmoore
Old Sep 3, 2003 | 05:06 PM
94jaxgsr's Avatar
Default Re: jrsc problem O2 code (tegunderpressure)
where is a good place to get one and what kind is the best to get so i dont run in to the problem in the future?
Old Sep 3, 2003 | 05:15 PM
MooreBoost's Avatar
Jegs has them. Just search online for them... Any kind should work.
gmoore
Old Sep 4, 2003 | 08:51 AM
TOFU.man's Avatar
uhh is it the catalyist effency code i dont get the o2 code but i get that code with my test pipe in you aught to check and see if that is your problem first.
Old Sep 4, 2003 | 09:06 AM
Spunkster's Avatar
Or you can get a Hondata and get it fully tuned. Since it uses an OBD1 ecu, it only uses the primary O2 sensor and you willl not have the code anymore.
Civic420life
Engine Management and Tuning
May 10, 2014 11:48 AM
the jdmchop
May 23, 2006 11:26 AM
JD95hatch
May 18, 2006 02:51 PM
draxxus07
Sep 29, 2005 11:35 AM
EG2 SiR
Mar 4, 2004 10:35 AM
