engine code(running too lean in bamk one) with afc????
Old Nov 28, 2003 | 09:01 AM
boost fed ls's Avatar
Default engine code(running too lean in bamk one) with afc????
for the past 2 months i have been running the afc hack with 450cc injectors and running 5 psi ,my afc settings were -40 from 1000-3000 and -37 from 4000-7000. Then decided to hook my mbc and run 8psi with the same settings since i was running rich, then I threw a rinning to lean in bank one code. I was wondering if this had happened to anyone before?? and all so throwing random mis-fire codes in cyl.1,2,3,4
Old Nov 28, 2003 | 09:04 AM
baphomet's Avatar
Default Re: engine code(running too lean in bamk one) with afc???? (boost fed ls)
ug? You do have an I-4 right? Which equals 1 bank of cylinders. Check your plug wires and your plugs if you haven't already.
Old Nov 28, 2003 | 09:08 AM
Default Re: engine code(running too lean in bamk one) with afc???? (slashDEVslashNULL)
yes, could plug wires cause mis-fire? a buddy and I have the same prob. and we both have msd wires.
Old Nov 28, 2003 | 09:24 AM
baphomet's Avatar
My brother had a misfire in cyl. 4 on his vr6. Turned out the plug wire wasn't seated correctly. Are your plugs gaped correctly?
Old Nov 29, 2003 | 04:51 AM
yes to factory spec.
Old Nov 29, 2003 | 04:54 AM
Mr.DC2TurBo's Avatar
have u set your in/out to 6??
Old Nov 29, 2003 | 05:09 AM
Default Re: engine code(running too lean in bamk one) with afc???? (Mr.DC2TurBo)
yes but there is some settings on my afc like dec air and some other features that i have no clue what they do, any ideas??
Sylv
12
Mar 16, 2010 07:35 AM
chicken head
Jun 22, 2006 06:13 AM
Tinker219
Oct 25, 2002 05:49 PM
RaVAGE00
Sep 26, 2001 11:42 AM
