Dumb timing question
Old Nov 26, 2003 | 07:17 AM
ARACER25's Avatar
Default Dumb timing question
I know its been covered but for somereason I can't seem to find what I need right now. I am looking to pull some timing because my plugs are white. For now I think I can move the disturbtor aft towards the firewall to retard? I am running stock injectors, 255 high flow intank pump, 12:1 FMU, B&M FPR stock press, missing link, stock P72 OBDII ECU, 7 psi intercooled, VAFCII set to zero, 9:1 compression.
Old Nov 26, 2003 | 09:30 AM
Flamenco-T's Avatar
Default Re: Dumb timing question (ARACER25)
you need a timing gun to check and see how much timing you are pulling or adding..
stan
Old Nov 26, 2003 | 09:36 AM
ARACER25's Avatar
Yeah I dont have and adjustable light right now but here is a pic of the plug. I just wanted to back it off a little to be safe cause I have a 1500 mile drive home.
Modified by ARACER25 at 12:13 PM 11/26/2003
Old Nov 26, 2003 | 09:49 AM
Mase's Avatar
just dont boost a lot, you'll be fine.
moving the dizzy towards the firewall actually advances the timing.
but dont change ur timing unless you have a timing gun/jump the ecu
Old Nov 26, 2003 | 09:54 AM
ARACER25's Avatar
Default Re: Dumb timing question (Mase)
I just want to recheck but moving the dizzy toward the firefall advances or retards timing??? Please someone double check cause I thought moving it towards the firefall retarded the timing.
OK I got it:
Modified by ARACER25 at 12:11 PM 11/26/2003
Old Nov 26, 2003 | 05:21 PM
scttydb411's Avatar
that plug looks normal if you are just cruising. your engine is going to go to 14.7 out of boost. did you pull those right after a hardpull without letting off/cruising? if you did that and they still look like that then maybe. did you shake them into your palm to look for metal specks falling out?
93lsv_turbo
Apr 15, 2011 12:08 PM
spoolingb20
Apr 26, 2006 10:46 AM
wzcb08
May 19, 2003 07:47 PM
DIRep972
Sep 22, 2002 02:29 PM
C4wrx
Feb 6, 2002 07:08 AM
