Intercooler (water) sprayer Kits?
Old Nov 25, 2003 | 05:54 PM
enigmaspeed27's Avatar
Default Intercooler (water) sprayer Kits?
Can someone help me find a kit.
Modified by enigmaspeed27 at 10:16 PM 11/25/2003
Old Nov 25, 2003 | 06:23 PM
baphomet's Avatar
Default Re: Intercooler (water) sprayer Kits? (enigmaspeed27)
Why don't you make your own?
Old Nov 25, 2003 | 07:51 PM
Kelly.'s Avatar
I've quit using this account
how could you make your own?
just put sprayers down by the IC and reroute the tubes?
it cant be that simple.. can it?
any links?
Old Nov 25, 2003 | 07:54 PM
Bailhatch's Avatar
Default Re: (llewsirc)
take your rear washer pump (if you have one) and run it to the IC. push button to spray, easy i guess. no reason it wouldent work.
Old Nov 25, 2003 | 09:55 PM
out there's Avatar
Default Re: (Bailhatch)
check out http://www.intercoolertechniques.com
you may want to use alcohol instead, it evaporates faster than water, perhaps compressed co2
Old Nov 25, 2003 | 10:13 PM
JM Performance's Avatar
Default Re: (out there)
in the latest SCC they do it on project silvia. (BTW, the issue sucks! its all burnouts )
Old Nov 26, 2003 | 12:04 AM
DownBoyDown's Avatar
Yeah I just got it today. Issue definately sucks. I dont know why they have articles on Ford Focuses and Festivas.
Old Nov 26, 2003 | 04:49 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (DownBoyDown)
Why not go to home depot and go to the drip water irragation system then re wire the car's water sprayer system. Where the bottom of the spray tank is. where it already gets split off to the rear cut the hose and go with a controlled duplex out let where there's a **** to control flow (100/0; 50/50; 0/100) Then empty the washer tank, and fill it with distilled water.
Old Nov 26, 2003 | 06:12 AM
VTC_CiViC's Avatar
Default Re: (neuspeed)
Why distilled water?
Old Nov 26, 2003 | 06:15 AM
Jay J's Avatar
Prince of Zamunda
Default Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">Why distilled water?</TD></TR></TABLE> Regualar water is bad for raw steel and alloy parts. Such as for a radiator u use distilled water and also to spray in a IC you should also use distilled water
Old Nov 26, 2003 | 06:39 AM
AP-Signworks1's Avatar
But you're spraying the outside of the intercooler. How much worse could regular water be when rain, road dirt, and all the crap is already getting sprayed on there? Just curious. I understand the radiator because that's on the inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote"> Regualar water is bad for raw steel and alloy parts. Such as for a radiator u use distilled water and also to spray in a IC you should also use distilled water </TD></TR></TABLE>
kings**t
Nov 15, 2008 03:53 PM
TurboTeG4
Sep 27, 2003 10:51 PM
Jockobo
Jun 13, 2002 02:03 PM
Smoothy
Jun 3, 2002 06:33 PM
SlowB16
Apr 4, 2002 07:51 PM
