What does the knock sensor look like, in this picture.
Old Nov 27, 2003 | 12:42 PM
The-LS's Avatar
Default What does the knock sensor look like, in this picture.
Okay, need some help here as my knowledge isn't that great about this sensor. I'm getting no reading from this sensor now and want to check up on it. I'll have to feel for it from below but I'm not sure which is the Knock sensor. Is it the one above the oil filter and the pipe or is it the one directly to the left of the oil filter? This picture isn't of my car obviously but its useful for what I'm trying to talk about. TIA
Old Nov 27, 2003 | 12:45 PM
ninesecrx's Avatar
Default Re: What does the knock sensor look like, in this picture. (Black-LS)
The grey plugged sensor above the water pipe.
Old Nov 27, 2003 | 12:59 PM
The-LS's Avatar
Default Re: What does the knock sensor look like, in this picture. (ninesecrx)
had a feeling that was the one thanks man... I can get back to work now...
Old Nov 27, 2003 | 04:54 PM
The-LS's Avatar
are all B-series knock sensors interchangable? I was thinking to save a few bucks buying one from a Honda motor dealership? Or is there a better alternative/aftermarket KS I should get that doesn't cost a arm and a leg? Is the one in C-speedracing's website (http://www.c-speedracing.com/howto/lsvtec/lsvtec.php) a stock KS? Which model Honda would have the cheapest price for a KS from a dealership? TIA again
Old Nov 28, 2003 | 10:23 AM
The-LS's Avatar
No help on this?
Old Nov 28, 2003 | 10:34 AM
Flamenco-T's Avatar
all should be the same, there are only a few cars mostly with VTEC that will have it...B16, B18C and etc...they're all interchangeable
stan
Old Nov 28, 2003 | 12:48 PM
ninesecrx's Avatar
Default Re: What does the knock sensor look like, in this picture. (Flamenco-T)
If it was me, i'd get a single cam ecu chiped so you didnt have to run a knock sensor.
Old Mar 31, 2005 | 06:18 PM
DocSean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black-LS &raquo;</TD></TR><TR><TD CLASS="quote">are all B-series knock sensors interchangable? I was thinking to save a few bucks buying one from a Honda motor dealership? Or is there a better alternative/aftermarket KS I should get that doesn't cost a arm and a leg? Is the one in C-speedracing's website (http://www.c-speedracing.com/howto/lsvtec/lsvtec.php) a stock KS? Which model Honda would have the cheapest price for a KS from a dealership? TIA again
what sensor is the green one? oil pressure sending unit???
Because on my b18a I have one, someone said it was the knock but I didn't think so. Also, there is no wire going to it....is that right???
Old Mar 31, 2005 | 08:48 PM
SSBPGSR's Avatar
Default Re: What does the knock sensor look like, in this picture. (spankjelly)
no, the green one is not the oil pressure sesnor. the one below it is with that little black boot around it, not sure what the greene one is. i have an extra knock sensor if u need one. PM me
Old Mar 31, 2005 | 09:00 PM
DaveF's Avatar
Default Re: What does the knock sensor look like, in this picture. (SSBPGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">no, the green one is not the oil pressure sesnor. the one below it is with that little black boot around it, not sure what the greene one is. i have an extra knock sensor if u need one. PM me </TD></TR></TABLE>
its either the coolant temp or the fan switch on non obd cars.(the green one)
Old Mar 31, 2005 | 09:31 PM
DocSean's Avatar
Is it bad that I don't have a wire running to mine?
Old Mar 31, 2005 | 10:58 PM
riceball777's Avatar
teh green sensor checks the coolent temp and switches the fans on when it reaches a certain temp
94+ civic and integras have it on the thermostate housing
Old Mar 31, 2005 | 11:07 PM
SSBPGSR's Avatar
Default Re: What does the knock sensor look like, in this picture. (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">teh green sensor checks the coolent temp and switches the fans on when it reaches a certain temp
94+ civic and integras have it on the thermostate housing </TD></TR></TABLE>
didnt know that, now i do...
Old Mar 31, 2005 | 11:19 PM
D@nnY's Avatar
yes the gray plug is the knock sensor and its 140 at an acura dealer list price...
The green is the coolant temp sensor which on some motors is on the side not the back....both those plugs will plug into the knock sensor and its common for them to be accidentaly switched
linzy
Honda Civic (2001 - 2005)
Jan 21, 2013 05:27 PM
rorik
May 27, 2008 05:48 PM
one-cam
22
Feb 28, 2008 07:37 AM
hatch34
Mar 16, 2005 01:03 PM
shadykit
18
Mar 14, 2005 12:51 PM
