Nitrous Push button setup or MSD window switch
Old Nov 26, 2003 | 09:31 AM
turbo*s2k's Avatar
Default Nitrous Push button setup or MSD window switch
I just recently installed an NXL kit on my Civic Si to go along with my Turbo kit that has yet to be installed. (Still breaking in the motor!) I'm not sure if I want to go RPM activated with a window switch or push button. The push button setup might be a little risky, but I'm considering it.
If you have a push button setup on your Nitrous kit. Can you post some picture's or let me know what you used to set it up? Thanks!
Old Nov 26, 2003 | 03:58 PM
turbo*s2k's Avatar
Default Re: Nitrous Push button setup or MSD window switch (TurboChrgd_Civic)
ttt
Old Nov 26, 2003 | 04:04 PM
tegasaurus's Avatar
here's a pic of my push button setup
i don't see why you would even consider using anything but rpm activated?
Old Nov 26, 2003 | 04:38 PM
shortyz's Avatar
Default Re: Nitrous Push button setup or MSD window switch (tegasaurus)
rofl!!!
Old Nov 26, 2003 | 06:41 PM
ScrapinSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
i don't see why you would even consider using anything but rpm activated?</TD></TR></TABLE>
personal preference really... I run a push button in my girl's n2o setup in her car... You run a Full Throttle... I also have setup vehicles using a full throttle switch and then just an activation switch in the car... That way you just flip an arm switch
Old Nov 26, 2003 | 09:39 PM
turbo*s2k's Avatar
Default Re: Nitrous Push button setup or MSD window switch (ScrapinSi)
I have the WOT thottle switch and arming switch that the NXL kit came with. I'm leaning towards an MSD RPM activated.
Old Nov 27, 2003 | 07:45 AM
wolfsburg2's Avatar
the window switch is safer. for the money its worth it imo.
Old Nov 27, 2003 | 08:29 AM
boosted92's Avatar
Default Re: Nitrous Push button setup or MSD window switch (wolfsburg2)
Run the window switch, WOT switch, and a FPSS.
Old Nov 28, 2003 | 11:22 AM
turbo*s2k's Avatar
Default Re: Nitrous Push button setup or MSD window switch (boosted92)
What does FPSS stand for?
Old Nov 28, 2003 | 12:19 PM
laughinxxx's Avatar
New User
fuel pressure safety switch.
I'm running a 225lph walboro pump, so i don't worry about fuel pressure running low.
Personally, I run an arming switch and a throttle activated microswitch. When I race I'm never below 3k rpm, so a window switch isn't necessary. I do have an MSD dig 6, with the rev limiter set before fuel cut though.
wushubrian
20
May 2, 2006 07:50 AM
05 S2K Stoner
Honda S2000
18
May 9, 2005 07:39 PM
gookspeed
Mar 7, 2005 11:23 AM
IhateMy93BlackHatch
Dec 11, 2002 09:02 PM
teggygsr
May 5, 2002 07:46 AM
