Just got it started ... is it ok to....
Old Nov 26, 2003 | 11:56 PM
djnikko's Avatar
Default Just got it started ... is it ok to....
I just got my turbo honda started last night with all the bits in place, soon to be ready for a test drive. however i just wanna know if its ok to give the car a good rev whilst in neutral (when warmed up of course). will i see boost in neutral? and would i hear anything from the BOV?
the engine is a ZC honda running 5 PSI
thanks
Old Nov 27, 2003 | 12:00 AM
Drew Peacock's Avatar
Default Re: Just got it started ... is it ok to.... (djnikko)
No you won't see boost in neutral not enough load on the engine you may get some noise from the BOV if you hit the gas hard enough... Depending on BOV adjustment etc
Old Nov 27, 2003 | 12:27 AM
bretx0r's Avatar
Default Re: Just got it started ... is it ok to.... (turbozxi)
if you punch it in neutral and really rev it at 100% throttle the BOV will go off
Old Nov 27, 2003 | 01:42 AM
djnikko's Avatar
Default Re: Just got it started ... is it ok to.... (bretx0r)
is this recommended as ive only just got the engine started? I want to but scared something will go pop
as long as im overfuelling then everything will be ok right?
thanks
Old Nov 27, 2003 | 05:05 AM
Johnyquest's Avatar
If you manage to do somthing (ie blow your motor) in neutral then you deserve a prize!! You'll be fine, but why not just go drive the thing already?
Old Nov 27, 2003 | 08:46 AM
djnikko's Avatar
Default Re: Just got it started again... idle problem
well i just started it up for the second time, started first time
i left it to heat up so the temp gauge was at the half way mark then i gave it a good rev upto 6/7k. everything is good except then i felt it and it started to hesitate on idle and stalled. does anyone know the cause of this? too much fuel at low revs? not enough fuel?could it also be my idling valve?? EAVC?? I have heard stories about people replacing these or cleaning them up then replacing them.... it wont hurt to do this right.... my 1000rpm setting on my SAFC is -44 1600 reads -42
any help appreciated
Old Nov 27, 2003 | 10:43 AM
teal EJ1's Avatar
Default Re: Just got it started again... idle problem (djnikko)
Id say you need to richen it up a little. My 1000rpm setting is at -25 or so. Play around with the settings a bit because every car runs a little different.
yeah_its_boosted
Sep 14, 2006 12:15 PM
Integra_drk
May 23, 2006 06:29 AM
ITSTOCK
Oct 19, 2003 05:59 AM
DOHCarp
May 31, 2003 09:17 AM
Mr. Vapor
Nov 15, 2001 05:43 PM
