afc hack with jrsc
Old Nov 27, 2003 | 11:55 AM
csmsi311's Avatar
Default afc hack with jrsc
Hi
I've been searching, but i haven't found what i'm looking for.
I have a 99 si with a jrsc. I've been running a SMC+ for the past year. Part of the SMC+ install was relocating the MAP sensor so it sees boost.
Do I keep the MAP sensor relocated? or put it back on the throttle body (where it doesn't see boost)
Thanks for your help
jason
Old Nov 28, 2003 | 01:11 PM
csmsi311's Avatar
Default Re: afc hack with jrsc (csmsi311)
bump
someone has to know the answer to this simple question.
Old Nov 28, 2003 | 01:18 PM
Johnyquest's Avatar
it needs to see boost; you obviously knew that from what you stated... what is your question?
it is part of the hack, as you stated...
Old Nov 28, 2003 | 02:10 PM
csmsi311's Avatar
Default Re: afc hack with jrsc (Johnyquest)
opps.. i reread. i meant with the afc hack does the MAP sensor need to be relocated with a jrsc.
and so the answer is yes
Old Nov 28, 2003 | 03:02 PM
MADEINIRAQ's Avatar
yes
sixfourkiller
Jan 3, 2011 09:36 AM
integra123
Dec 7, 2005 03:29 PM
hondaeg8
Jul 29, 2005 07:41 PM
Pfieff
Jun 13, 2003 12:03 PM
GreddySi99
Mar 17, 2003 03:15 PM
