MSD 2-step installation
Old Nov 27, 2003 | 11:23 AM
tyflip2's Avatar
Default MSD 2-step installation
can you hook up an MSD 2-step without using the msd 6 ignition box. is there any way to wire it up with out the box. i need help. thanks alot
Old Nov 27, 2003 | 11:51 AM
DOHCarp's Avatar
Default Re: MSD 2-step installation (tyflip2)
I think to use the two step you at the very least need a MSD soft touch rev control.
Taken from msd's website....
"The Module Selectors must be used with an MSD Soft Touch Rev Control or a Timing Controller with a high speed retard module. No rpm or retard modules are supplied."
http://msdignition.com/rpm_6.htm
Old Nov 27, 2003 | 12:02 PM
RenoRacing's Avatar
Default Re: MSD 2-step installation (DOHCarp)
Yeah, you'd need to use a MSD softtouch rev control or limiter of sorts. the Two step itself just kinda acts like a switch that changes the rev limiter between two different pills or rpms.
this post kinda explains it.
https://honda-tech.com/zerothread?id=664905
http://store.summitracing.com/...image
90tegboosted
Engine Management and Tuning
May 24, 2013 04:31 PM
CIVICD16A9
Jul 4, 2005 08:26 AM
M.A.R.C.
Jun 20, 2004 02:56 PM
TodaCivic
May 28, 2003 12:50 AM
Rhetoric
Dec 16, 2001 12:05 PM
