oil feed line
Old Nov 27, 2003 | 03:30 PM
GSR x13's Avatar
Default oil feed line
on the oil feed line (breadead stainless steel line) what size nipple fits into that?
-4?? im buying that "take off fitting" and need to know what size the nipple is.
Old Nov 27, 2003 | 04:09 PM
roydogg's Avatar
Default Re: oil feed line (Question)
I think it's -3AN
Old Nov 27, 2003 | 04:20 PM
RenoRacing's Avatar
Default Re: oil feed line (roydogg)
it depends on which fitting you get and which line you get. standard is either -4 an or -3 an. It just depends which kit you get or piece together.
Stan will be able to help you out and offers just a feed kit w/ the two fittings you need for a good price and is more than willing to answer any questions that you have along the way! I"m sure for $40 you'd be set.
Old Nov 27, 2003 | 06:34 PM
GSR x13's Avatar
whose stan?
Old Nov 27, 2003 | 07:05 PM
mos's Avatar
mos
Default Re: (Question)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Question &raquo;</TD></TR><TR><TD CLASS="quote">whose stan?</TD></TR></TABLE>
Whose Stan? Your stan.
Who is Stan? Flamenco-T.
People on HT have had problems with too much oil reaching the turbo, with both 3/16" and 1/4" hose... Maybe you'll have less chances of experiencing problems with 3/16" hose.
Old Nov 27, 2003 | 07:11 PM
RenoRacing's Avatar
Default Re: (mos)
Stan Stan the fitting man! if he can't fit it no one can
Old Nov 27, 2003 | 10:57 PM
Flamenco-T's Avatar
Default Re: (RenoRacing)
I am Stan
tell me what you have and I'll give you the details of what you're needing as far as the fittings that are missing.
Stan
stan@fast-turbo.com
Old Dec 1, 2003 | 10:52 PM
GSR x13's Avatar
It was nice getting advice and help from you stan.. KEEP UP THE GOOD WORK..
Old Dec 2, 2003 | 09:27 PM
ef88's Avatar
Default Re: (Flamenco-T)
hey stan..im looking for the oil feed line and return line. I need the return line with the drain flange from the turbo if you have it..and also the oil feed line, i only need fittings from the turbo and the oil line. i already have the fittings on the oil pressure side...
Old Dec 2, 2003 | 10:11 PM
Flamenco-T's Avatar
Default Re: (ef88)
EF88, please check your IM
stan
092eg6
Aug 2, 2010 01:18 PM
gooberguy31
Feb 25, 2009 12:09 PM
SOHC_2_DOHC
Oct 30, 2007 06:06 AM
seeeya04
Dec 12, 2005 05:08 PM
slammin86
Jun 5, 2005 10:07 PM
