D15B2 "DX" head vs D16A6 head under boost ??
My D16A6 head got worped b/c my radiator took a ****.... it over heated and now the water jacket is leaking into/out of the cylinders.
My question is... Do you guys think there is going to be a great difference in power under boost if I use my old D15b2 "DX" head ??
The DX head has the same EVERYTHING, minus the cam.. The A6 cam is said to rev a little higher vs the B2 making better torque....
I'm thinking that 13psi is enough to make any head/cam flow pretty good either way... And yes I'm "that broke" that I don't wanna pay $100 to get the A6 head decked, save the "just get it decked" comments.
13psi with A6 = 200hp ( hypitheticlly )
13psi with B2 = 195hp ????
5hp lost ??? more???
New User
Re: D15B2 "DX" head vs D16A6 head under boost ?? (89dxhunchback)
Over heating may be more than jsut the head. But I am sure you know that.
I can't remember, but does the Dx head have different quench areas? Will it change your comp ratio? My bet is that you will loose a good amount of power due to the smaller ports. But i bet you won't tell the difference except at high rpm.
Find someone doing a ZC swap or B16 swap and get their engine for free. There is a guy in altanta giving his away on CRX resource board, or was it CRX performance board? I can't remember.
D16's are plentiful.
Randy
Randy
Re: D15B2 "DX" head vs D16A6 head under boost ?? (RGAZ)
youll be ok with the b2 head. the valve springs are different and so is the cam.
the castings are the same.
i just went lookin for the same info rescently.
good luck.
d.
good luck.
d.
Re: D15B2 "DX" head vs D16A6 head under boost ?? (dvious hatchie)
Yea the ports are the same as well as the combustion cambers CC. I have a 1.6L motor so the smaller displacment isn't an issue, just the cam. I wasn't aware that the va;ve springs are different...
I was just wondering if the cam was really going to make that big of a difference.
As far as swaping the cam.... Its not worth the trouble IMO, there is a lot of stuff in the valve train that can get screwed up if it isn't assimled right..
I guess I'll find out... I'm about to go outside and swap it now...
I know that head is the cause of over heating b/c I replaced my therostat and I also have a full size radiator with one pusher fan on the turbo side and one puller fan on the other side ( trust me it moves some serous air !!! ) and they are both hard wired to the ignition ( always on ).
When I pulled the head off I could see the black marks on the block walls ( not the sleeve walls, the block walls ) where the gasket was blown/ head lifted.
Stupid bugs chaced me inside, until it gets a little colder out side head and block are both cleaned, just have to torque down and reassimble ).
BlingBlingCivic
05-12-2005 08:09 AM
4th gen civic racer
01-26-2005 06:39 AM
89dxhunchback
11-26-2003 04:57 AM
