pistons and ringlands
Old Nov 26, 2003 | 03:53 PM
ludelvr's Avatar
Default pistons and ringlands
So if a ringland goes, can u simply replace the rinland or do you have to replace the entire piston? Also, if you do have to replace the piston, do you have to do anything else to the cylinder walls?
Old Nov 26, 2003 | 03:55 PM
tegasaurus's Avatar
Default Re: pistons and ringlands (ludelvr)
must replace piston. hone cylinder walls for the new rings, and if a bore is necessary, bore, then hone.
Old Nov 26, 2003 | 03:56 PM
ludelvr's Avatar
Default Re: pistons and ringlands (tegasaurus)
is this even when you're replacing with factory spec pistons?
deanobob123
Apr 9, 2018 12:16 PM
Ep3tat98
K Series
Feb 3, 2016 10:20 PM
5_Lug_B
Aug 5, 2007 09:26 PM
B20LS-T
May 13, 2003 04:17 PM
ek
Jun 10, 2002 08:52 AM
