need help removing stock coil and adding msd coil
Old Nov 26, 2003 | 02:17 PM
B_1_8_hatch's Avatar
Default need help removing stock coil and adding msd coil
i'm adding an msd kit on my car. when you remove the stock coil, there are two wires that connect to the stock coil. one is grey and yellow and the other is yellow and blue, i may have got the colors wrong. where do i put those wires when i take them off the stock coil? i didn't put them anywhere at first and when i tried to turn on my car, it wouldn't start.
can somebody explain to me how to do this or let me know of any good websites with instructions.
TIA
Old Nov 26, 2003 | 08:23 PM
Default Re: need help removing stock coil and adding msd coil (93hb)
http://www.msdignition.com/pdf/pdf24.pdf
is this correct?
Old Nov 28, 2003 | 12:55 PM
anyone know who has installed an msd sci????
Old Nov 28, 2003 | 07:20 PM
Garrette99's Avatar
Which msd ignition parts are you using?, 8207 and Digital SCI plus ? If so, the blk/yellow and white/blu wires inside the distributor will run to the msd ignition box, blk/yellow goes to red, and the white/blu goes to the white. And then the Black and orange wires from the msd unit will go the the new coil, Orange to positive and black to negative, hope this helps?
Old Nov 28, 2003 | 07:57 PM
msd sci, msd cap 8292, msd blaster 3 coil
i figured it goes like this:
thick red to battery
thick black to battery
orange to blaster 3 coil
black to blaster 3 coil
thin red to one of the wires that disconnects from the stock coil
white to the other wire that disconnects from the stock coil
is that right?
Old Nov 28, 2003 | 08:05 PM
Garrette99's Avatar
YOU GOT IT !
Old Nov 28, 2003 | 08:28 PM
Default Re: need help removing stock coil and adding msd coil (Garrette99)
redlinez_r_us
May 28, 2010 12:05 PM
justint
Feb 24, 2007 08:46 PM
RACING INTEGRATION
Oct 4, 2005 11:05 PM
juicedh22
Oct 9, 2004 05:45 AM
