Best place to put AVCR in Si???
Wondering if anyone had any pics of the Apexi AVCR Boost Controller in their 99-00 si's? Trying to debate where I can put mine where it looks good, stays somewhat hidden, and is functionable for me to use without hassle....
Re: Best place to put AVCR in Si??? (jz)
yeah that's true....I'd like to keep it smooth looking like I did it before with my old setup but going to have a hard time doing that since it's bigger..
old setup: http://f1.pg.photos.yahoo.com/...iew=t
Re: Best place to put AVCR in Si??? (Bulldogg83)
I had my vafc same size as avcr mounted were my rearview mirror was and you couldnt se it from outside unless it was on. It will fold up nicely you can use the apex mounting bracket in 2 of the holes from the mirror
Alright dueche . . . here is what we do.
1) buy a hinge (black) that is the same size as the cubby behind the cup holders.
2)drill one side of the hinge to top side of cubby hole and fasten it in
3)put some crazy adhesive velcro on the part of the hinge that comes down and on the back of the AVCR.
4)smoke a fatty and stare at the masterpeice
The hinge will allow you to pull it down when you want to see it and after you're done you can push it back up flush with the top of the cubby holder
SNOOGINS!
SNOOGINS!
Re: Best place to put AVCR in Si??? (tSuperbike69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tSuperbike69 »</TD></TR><TR><TD CLASS="quote">I had my vafc same size as avcr mounted were my rearview mirror was and you couldnt se it from outside unless it was on. It will fold up nicely you can use the apex mounting bracket in 2 of the holes from the mirror</TD></TR></TABLE>
Damit, that's what I was going to tell you to do. I had my VAFC, and my AVCR mounted above my rear view. It looks clean!!!!
Re: Best place to put AVCR in Si??? (AVATAR)
Pics of above the rearview mirror would be nice....
That's also not that bad of an idea to do the thing with the hinge...
.RTErnie
11-04-2005 07:54 PM
