Ceramic coating the inside of the turbine housing.
Hi there,
I have a T3 (.48 hot .60 cold) that will be ceramic coated. I am going to get the turbine housing ceramic coated, then someone mentioned about getting the inside coated.
Can I get the inside of hte housing ceramic coated without worrying about tolerances from the turbine itself? If there is any doubt I will just get the outside coated. Thanks!
Bump....
I'd like to know too.
My guess is that it might affect your A/R slightly. Ceramic coatings are very very thin. That and the added heat that is kept in the housing might cause a faster spool up..... (waits for someone who has done it to stand up)
