What Do You Think About My Setup!!
Old Nov 24, 2003 | 11:03 PM
oemDC2's Avatar
Default What Do You Think About My Setup!!
95 GSR (stock internals), turbonetics TO4B (dont know the trim a/r), spark racing 35mm wastegate .4bar spring, spark racing manifold, spark racing fmic, hondata S200 with boost option, walbro 255 lph fuel pump, 440cc injectors, blitz dd bov, blitz dcII turbo timer, NGK spark plugs (2-step colder), Clutch Specialties stage 3 6 puck clutch, 2.5 inch Es Oval muffler with 2.5 inch custom exhasut piping, 2.5 carsound cat. What do you people think about my setup?
Old Nov 24, 2003 | 11:04 PM
Mase's Avatar
Default Re: What Do You Think About My Setup!! (oemDC2)
honestly....ditch the manifold and u'll be ok
Old Nov 24, 2003 | 11:06 PM
Unsung's Avatar
Default Re: What Do You Think About My Setup!! (Mase)
What are your goals?
Old Nov 24, 2003 | 11:08 PM
oemDC2's Avatar
Whats wrong with the mani?
Old Nov 24, 2003 | 11:11 PM
oemDC2's Avatar
Default Re: What Do You Think About My Setup!! (Unsung EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsung EM1 &raquo;</TD></TR><TR><TD CLASS="quote">What are your goals?</TD></TR></TABLE>
For now i just want to get everything up and runnng, only running about 5.8 psi on my stock motor, i will eventually built my block, im thinking about 2.0L in about a year or so, until then i only want to run low boost and see how that does..
Old Nov 24, 2003 | 11:32 PM
Unsung's Avatar
I would ditch all the spark stuff, go with a inline pro manifold, tial wastegate, precision intercooler, and go with a 3" downpipe and full exhaust. Everyone will have a different opinion, but based on the stuff I've learned from this forum, those would be my changes.
Old Nov 24, 2003 | 11:36 PM
oemDC2's Avatar
I just want a basic setup for now, you think i'll be fine with what i have? I got a killer deal on my setup, but will probably get different mani, WG, etc. in the future. DO you also think my TO4B is too big for what ill be boosting? I get a lot of different responses...
Old Nov 24, 2003 | 11:37 PM
redboost10's Avatar
may i ask how much your getting that turbo for?
Old Nov 24, 2003 | 11:39 PM
Unsung's Avatar
Do you have the turbo yet? Can you take pics/measurements? Do you see any AR markings on the castings? It really depends on the size of the turbo. As for a temporary setup since you got it for a good deal, it'll work fine.... probably have some turbo lag considering the dp/exhaust/turbo combo you'll be using.
Old Nov 25, 2003 | 05:49 AM
RedTegLS's Avatar
From what I am learning that 2.5" exhaust is going to be very restrictive. Try and get 3". kteller sells nice stuff and you can find thermals for around $450 + shipping if your a baller!
Old Nov 25, 2003 | 04:10 PM
oemDC2's Avatar
Default Re: What Do You Think About My Setup!! (RedTegLS)
Anyone else?
Old Nov 25, 2003 | 04:30 PM
Garcia-Racing's Avatar
I think your set up sounds ok. The sparks manifold may crack from the weight. Try welding on a support bracket to the block. With a turbo that big you also might expect to feel a lot of turbo lag. A t3/t4 may have been a better choice. You also could look into getting a smaller exhaust housing put on it.
FRernesto
Mar 13, 2008 05:36 AM
mrimmortal01
Feb 13, 2006 05:22 PM
Touge Tuning
Dec 10, 2004 10:34 PM
mattEG
Sep 14, 2004 09:22 AM
NCSTIdriver
Dec 21, 2002 01:10 PM
