N/A To JRSC
Old Nov 28, 2003 | 05:52 AM
BLK99VTECR's Avatar
Default N/A To JRSC
Does anyone know how motors with Cams, pistons and any other type of internal work react once a JRSC is installed?
Old Nov 28, 2003 | 05:56 AM
Tinker219's Avatar
Default Re: N/A To JRSC (BLK99VTECR)
itd be fast its all in the tuning. Stock GSR cams are some of the best cams out there to use for boost because of the low duration. W/NA cams though, if you just dial out some of the overlap w/the cam gears, you should be fine.
Old Nov 28, 2003 | 10:07 PM
BLK99VTECR's Avatar
im planning on getting CTR Cams
Old Dec 9, 2003 | 11:39 AM
BLK99VTECR's Avatar
Default Re: (BLK99VTECR)
does anyone ave any Dynos of JRSC engines with internals
Old Dec 9, 2003 | 12:42 PM
funky_cornbread's Avatar
what's all done to your car? compression? etc.
Old Dec 10, 2003 | 04:26 AM
BLK99VTECR's Avatar
Default Re: (funky_cornbread)
I havent done anything yet, Im just trying to find out will it be a waste of money to add internals. Someone told me a long time ago that they read some where that they dynoed a JRSC with after market cams and it actually lost power.
Old Dec 16, 2003 | 12:47 PM
FourDoorTypeR's Avatar
Usually by "internals", you're talking about stuff in the block i.e. pistons, rods, etc. I don't see how they could make you make any less power (Unless you dropped compression). Cams on the other hand, I'd stick with GSR cams as said earlier. Almost everyone I know running boost (turbo/super) around here swap to those cams because of the duration.
97_BB6
Mar 12, 2007 10:35 PM
TOFU.man
Jun 2, 2003 05:38 AM
Riptide101
Jul 8, 2002 06:51 AM
SCsol
Jun 2, 2002 12:39 PM
a z n t a k
Feb 13, 2002 04:22 PM
