arp head studs???/
Old Nov 26, 2003 | 08:37 PM
blu2ksi's Avatar
Default arp head studs???/
are these really worth it b16 only changing my cams and headgasket internally? i plan on running 7 lbs nothing big, exactly what do these do compared to stock?
Old Nov 26, 2003 | 08:57 PM
ghettocrxsi's Avatar
Default Re: arp head studs???/ (blu2ksi)
They work great on keeping your head from lifting from the block and warping under heat and stress from your extra hp. The Arp's have worked great ever since I have had them on my crx.
The 120 that you pay for them could just save you a head gasket and a milling when you warp your head.
Old Dec 12, 2003 | 12:32 PM
LonelyDriver02's Avatar
Default Re: arp head studs???/ (ghettocrxsi)
Where is the best place to buy arp head studs? My head gasket is bad, i think, and i want to get some stronger head studs while i'm replacing it. Does anyone know if the aebs studs are any good? Thanks.
Old Dec 12, 2003 | 11:27 PM
Kwuaymaikrup's Avatar
Default Re: arp head studs???/ (LonelyDriver02)
Look for "lightning" in the Sponsor Marketplace. He always has great deals on them. Or you could just PM him.
-Ryan
Old Dec 12, 2003 | 11:30 PM
94dxt's Avatar
Default Re: arp head studs???/ (Kwuaymaikrup)
I wouldn't boost a motor w/out them. Seen too many lifted heads
Old Dec 13, 2003 | 07:06 AM
maxim's Avatar
Last I checked lightning did not have them in stock. I know http://www.jegs.com had some a few weeks ago. They're a hot item, so be prepared to wait wherever you go.
Old Dec 13, 2003 | 07:18 AM
alpha's Avatar
Wired SpeedLabs might have them instock. Last time I spoke with Kyle he ordered a bunch.
Old Dec 13, 2003 | 09:57 AM
genop's Avatar
Just make sure you use the correct torque specs if you are installing them. Thats where most people mess up.
Old Dec 13, 2003 | 12:23 PM
TurboR1391's Avatar
Default Re: arp head studs???/ (genop)
I have used ARPs from the get go with no problems. I have actually found summit to have the best prices on ARPs.
Old Dec 13, 2003 | 12:30 PM
RenoRacing's Avatar
Default Re: arp head studs???/ (TurboR1391)
Anthony's got them. or Tom has the AEBS one's for a good price.
https://honda-tech.com/zerothread?id=684873
Old Dec 13, 2003 | 01:22 PM
kpt4321's Avatar
A couple things to note with these:
First of all, I would HUGHLY suggest that you use the ARP moly lube on them, not 30 weight oil. 30 weight oil requires a lot more torque, and is not nearly as consistient. I know people who have blown head gaskets using ARPs and 30 weight, and we theorize that it was because they were not torqued enough.
Summit sells tubes of the moly, if you need it.
Also, make sure that you torque the studs down in the proper pattern. You want to go from the inside of the head out, and you want to alternate from side to side and from top to bottom. If that doesn't make sense, let me know and I can explain it better. Also, you want to torque in steps, I do mine hand tight, then 40, then 70, then full torque.
Hope this helps.
Old Dec 13, 2003 | 01:27 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboR1391 &raquo;</TD></TR><TR><TD CLASS="quote">I have used ARPs from the get go with no problems. I have actually found summit to have the best prices on ARPs. </TD></TR></TABLE>
To my knowledge Summit doesn't help support HT though
DelSol-B18
Sep 8, 2012 06:24 PM
85mmek9
Apr 19, 2010 08:25 AM
ChRiS_p123
Apr 8, 2010 10:27 PM
boostedel
Jan 10, 2003 12:24 PM
RTW DC2R
Sep 9, 2002 01:58 PM
