IGNITION RETARD QUESTION
Old Nov 26, 2003 | 11:55 PM
djnikko's Avatar
Default IGNITION RETARD QUESTION
I am wondering if its safe to retard my ignition timing when using an MSD 6AL. I do not have MSD BTM, but will be retarding the distributor mechanically. I cant see how this wold cause a problem but thought i'd check...
thanks in advance
Old Nov 27, 2003 | 01:47 AM
djnikko's Avatar
Default Re: IGNITION RETARD QUESTION (djnikko)
at the moment i have stock ignition but slightly retarded. I am wondering if I put an MSD 6AL box onto the distributor can i still leave it retarded??? Surely someone out there must of done this....
Its only temporary till i can afford the BTM add on for this unit....
thanks
Old Nov 27, 2003 | 05:02 AM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">
thanks in advance</TD></TR></TABLE>
Don't you mean thanks in retard??
Of course you can set your timing however you want, regardless of where your spark comes from... Won't be a problem whatsoever
Old Nov 27, 2003 | 12:11 PM
RAWB's Avatar
Yeah, I ran with 2degree RETARD(mechanically) with my MSD 6A for 2 years , no prob, though.
Old Nov 27, 2003 | 12:27 PM
Mase's Avatar
how much are you boosting?
Old Nov 27, 2003 | 01:53 PM
b16ahybrid's Avatar
Default Re: IGNITION RETARD QUESTION (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">how much are you boosting?
Old Nov 28, 2003 | 12:33 AM
djnikko's Avatar
Default Re: IGNITION RETARD QUESTION (b16ahybrid)
i'll be boosting abotu 5 psi
Old Nov 28, 2003 | 05:53 AM
b16ahybrid's Avatar
What engine?
You should be fine with about 2 degree's of retard...
hany
Dec 23, 2006 04:55 PM
Rod.
Jan 7, 2005 08:00 AM
djnikko
Apr 23, 2004 12:29 AM
zcivic91
Sep 18, 2002 09:34 PM
