Optimum A/F ratio.
Old Nov 25, 2003 | 03:22 AM
BoostedD15B7's Avatar
Default Optimum A/F ratio.
What is the optimum air/fuel ratio for a turbo car? Around 14.1?
Old Nov 25, 2003 | 03:25 AM
ekb18c's Avatar
Default Re: Optimum A/F ratio. (BoostedD15B7)
14.1? Hmm No.
Every motor handles differently so I'm not comfortable in telling you a specifc afr is best for a car. The only way is to goto the dyno and let your tuner do it for you.
Old Nov 25, 2003 | 03:26 AM
EE_Chris's Avatar
The irony of your signature.....
Anyway, optimum is to be determined on the dyno/street with a wideband. But your typically looking at ~12.5:1 for a boosted car. 14.7:1 is considered stoic, which theoretically all the gas would combine with all the oxygen and all of it would get burned.
Old Nov 25, 2003 | 03:27 AM
Dee's Avatar
Dee
idle.. yes
boost .. HELL NO!!
Safe is 11.4~11.9
best power is 12.0~12.5!
Do not try 12.5 if you are not an excellent tuner with good gas readily available because a boost spike will easily kill a 12.5 AFR motor after the you go into a lean condition.
Old Nov 26, 2003 | 03:28 AM
Default Re: Optimum A/F ratio. (Dee)
Is there a decent wideband or a/f monitor for under $300 that is pretty accurate for tuning it on the street.
Old Nov 26, 2003 | 03:32 AM
rjardy's Avatar
techedge.
Rob
xero_xero
Engine Management and Tuning
103
Sep 6, 2011 07:53 PM
ej1252
Oct 26, 2007 05:15 AM
Msatterfield1988
Mar 14, 2007 07:04 PM
wfocrx
Jun 22, 2006 05:09 AM
GOLDBERG
Jun 2, 2003 02:15 PM
