***HELP! Greddy Profec b
Guest
Posts: n/a
Im about to install my greddy profec b and i just wanted to make sure what i was doing is right. i did research, but it made me more confused then b4.
so far this is what i came up with:
kind of whack
help me out, thanks in advance.
kind of whack
Re: ***HELP! Greddy Profec b (ek9vboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9vboi »</TD></TR><TR><TD CLASS="quote">Im about to install my greddy profec b and i just wanted to make sure what i was doing is right. i did research, but it made me more confused then b4.
kind of whack
help me out, thanks in advance.</TD></TR></TABLE>
kind of whack
I can't see the pics but heres what to do. I'm assuming you have an external wastegate. Run the side of the wastegate to the intake manifold like you would if you didn't even have a boost controller. Run the top of the wastegate to the "out" on the solenoid. Tap a fitting into your charge pipe pre throttle body. If you want the boost controller to read the pressure drop of the intercooler then tap it after the intercooler. Run this fitting to the "in" on the solenoid. Set the back for external wastegate. Red wire gets a switched 12v and black is ground. I guarantee this will work assuming your unit is in good working condition. I'm at work right now but I could get you pics later if you'd like.
99blusi
07-21-2005 09:20 PM
