V-AFC HACK
Old Nov 26, 2003 | 08:52 AM
riddickone's Avatar
Default V-AFC HACK
Ok I am trying to fully understand this hack here, I know it is simply DSM 450CC Injectors and V-AFC/S-AFC, V in my case, I am running a 95 Teg GSR, ok I want to boost 10 psi, which I hear is fine on the stock map sensor, but if I want to do 12 psi every now and then what should I do as far as the map goes
Choice 1: gm 3 bar
Choice 2: Missing Link
Second Question: I hear that the V-AFC hack will advance timing, which I guess is considered bad when running a turbo, SC , or nitrous. so should I retard the timing someone told me 3 degrees , is that correct or should it be more, thanks for all the help looking to do it this weekend,
I LOve HoNdaTeCh
Old Nov 26, 2003 | 09:08 AM
Johnyquest's Avatar
Default Re: V-AFC HACK (riddickone)
Drop your timing 3-5 degrees depending on how much / if you detonate, you can run like 10.5 lbs. It's pretty straightforward.
3bar / missing link aren't really options. If you want to run more than that, you should look into chipping (as I am).
Old Nov 26, 2003 | 09:11 AM
riddickone's Avatar
Default Re: V-AFC HACK (Johnyquest)
When you say chipping do you mean Hondata or Uberdata?? thanks for the help
Old Nov 26, 2003 | 11:26 AM
turb0rexx's Avatar
I think the 450cc injectors might be to big for the afc to control. Once u start leaning out the injectors the computer will advance your timing. If I were u i'll just get a Hondata. I got a Hondata in my car with 700cc injectors and it still idle and drive like a stock car.
Old Nov 26, 2003 | 11:52 AM
ndogg's Avatar
Default Re: V-AFC HACK (turb0rexx)
[QUOTE=turb0rexx]I think the 450cc injectors might be to big for the afc to control.QUOTE]
wow. you are on top of things.
Revi
Jul 8, 2004 07:27 PM
T3T495GSR
Jul 25, 2003 12:48 PM
boosted_dc2
Feb 25, 2003 11:38 AM
spike
Nov 21, 2002 08:30 AM
Boostless97Lude
Sep 6, 2002 02:11 PM
